SWK Nylon sporran
OK, as I said on this other thread, I wanted to provide folks some more detailed information on the new SWK nylon sporran, that can hold a 9-mm if needed. First off, I want to say that I only have 2 other sporrans, that have sufficed for everything I have needed so far, a plain black, three tassel one that you can find every where, and a fairly nice soft leather brown one off eBay.
Now the standard black one I have is fairly small, no separate compartments, and getting the change at the bottom is a challenge. In contrast this SWK is great. Now, I got mine off the blemish rack, but it is perfect. Just some bubbles on the back where it joins to the backing material, which nobody sees anyway. The following pics should help give some perspectve and details:
The front, notice that the flap has a zipper that opens to a small compartment that is great for coins and other small items:
The back (and you will have to adjust your sporran belt. The thingy with the loops that you clip to is wider than on most sporrans):
Showing the flap pulled up (fastened by velcro), and the underflap pocket, with gussets for expansion:
Another view of the under flap pocket:
