Results 1 to 10 of 19
    30th June 04
    Houston, Texas
    Two strapping it?
    Gents, ladies, rapscallions of either sex:
    I've done this with my SWK heavyweights (Merino wool) and standards (i.e. acrylic), particularly now that I've "skinnied down" a little. When I'm dressing, I simply tuck the underapron into place and fold the over-apron (or just apron?) over it, and buckle the right hip straps into place. I started this because, with the buckles on the last hole, the kilt was still a little bit big and loose on me.
    I've never done this with a poly-vis or poly-cotton kilt.
    Guess what I've noticed?
    No difference.
    The underapron doesn't try to wriggle loose or fall down. With the straps buckled on the right hip, it still fits and wears like a kilt should. The acrylic or wool clings to itself enough to stay in place.
    In fact, on my SWK Irish National, I ended up cutting the lower right strap and buckle loose, and secure the kilt with a single strap at the right waist.
    I know Matt Newsome (huzzah!) uses a single strap on each side of the waist, deleting the lower strap on the right hip entirely. But does anyone else have any experience using a single strap on the right?
    I'm just curious, here.
    23rd April 04
    Forest Grove, Oregon
    Smile Single right strap
    The SWK I own (3) are the only kilts I own (18) have two strap/buckle on the right side. So only one on the right is no big deal.
    Robert "the kilted" Lamb
    30th October 05
    Sugar Hill, Georgia
    I find that two straps are enough. With the third strap people tend to over tighten it anyway and will cause the kilt to distort. So you ask why do you include three straps and buckles on your kilts: because thats what people seem to want. But it is not necessary.
    9th June 06
    Midland, TX
    The only kilts I have that have three straps/buckles are the SWKs. The bottom/right strap on my Saffron has to be on the last hole in order to not distort the apron. So, I'm seriously considering removing it as it is most certainly not necessary.
    30th June 04
    Houston, Texas
    By way of clarification
    Gents:
    I fear that I poorly expressed myself. (I can babble with the best of them, but when it comes to technical writing, I am poor at best.)
    My question was not so much about leaving off the third strap on the right hip, as about not using the buckle and strap on the LEFT side of the kilt, as it is worn.
    Ever forward!
    19th September 04
    Ottawa, Ontario, Canada
    I seem to recall that Matt Newsome once made a kilt with no straps at all. He simply used the belt to hold it on.
    Shane
    9th September 06
    Greenville, SC
    Hmm... I have never tried that on my SWK. My reason for doing it would be different though. It seems that the hole for the left strap is too small and it takes a great deal of tugging and pulling to get it through, to the point that I wouldnt need to buckle it after getting it through.
    The bottom right strap gives me trouble as well and seems to distort the apron on all but the last notch. Of course I seem to have a rather large posterior:-)
