1st February 08, 04:19 PM
looks neat, but you forgot the drones, bag and reed!
1st February 08, 06:14 PM
Hi, Sean,
It's just pine (I only had a few days and so needed something soft) with a cherry block--I sealed it well then rubbed in a few coats of local beeswax which gives it a nice glow. I wasn't sure I could get anything to them via mail so wanted them to have it for the flight home.
The piece that's tied on, called the "block" or "bird," it what makes Native American flutes unusual...Most flutes around the world are a single tube and require a certain embouchure ( or "the way you hold your mouth") to play...NA flutes have two chambers sepearated by a piece of wood left inside--roughly under the block. You blow in one end, your breath tumbles around the first chamber, and then is directed by the block against the edge of a hole into the second chamber--this cause the air to vibrate and produce the sound.
Makes it easy to be able to play right away but still allows great expression. The block is tied on (as apposed to being fixed permanently) so you can adjust it slightly as needed for sound, and you can remove it after playing to let the flute dry out.
Moosedog
1st February 08, 06:21 PM
That's interesting, Moosedog. I like the music that gets played on those up in the Four Corners area, Window Rock...
2nd February 08, 10:36 PM
Neat! Can you post an audio???
4th February 08, 12:16 PM
Very nice. I made a flute out of....horrors...PVC pipe a while ago, but this is an awful lot nicer!
By Tartan Hiker in forum DIY Showroom
Last Post: 12th November 08, 09:13 PM
Last Post: 18th January 08, 08:58 PM
By BLAZN in forum DIY Showroom
Last Post: 20th January 07, 05:53 PM
By bubba in forum General Kilt Talk
Last Post: 12th March 04, 07:50 AM
