24th August 08, 10:20 AM
I think you'll find a lot of different answers to your last question - where "should" it be, where does one like to wear it could be anywhere, depending on one's aesthetic. On the my most recent kilt, the centerline of the top buckles (and in my case, only buckles) hits at my navel. Above that is two and a quarter inches, and the waistline is flared a bit extra to fit my torso. This is, for me, the most comfortable and proportionally correct kilt I have to date.
Be sure and check with your kiltmaker, however. Some will want the total length, but the measurement I gave was from centerline of the buckle (the natural waistline and smallest circumference) to the bottom edge.
Rex.
24th August 08, 11:37 AM
Ok Tommy, I found it:
The Wizard of BC's sticky thread "How to measure for a kilt - a video"
Now, that is for the kilts he makes, but he explains all of this very, very well. And yes you need to do what your kiltmaker tells you to do when you go to measure, but I think it helps to understand the terms and so on.
Good luck, Tommy.
24th August 08, 12:01 PM
Ok I think this gives me enough to go on - thanks guys and thank you Ted for posting the video. My waist seems to be just above the belly button and the waist is where the top of the kilt should be. This seems right to me but I will ask ken @ Houston when I order tomorrow.
25th August 08, 09:02 AM
If you order a traditional kilt, the kiltmaker will make it to be worn (as Ted says) with the center of the buckle at the waist. That puts the top of the kilt 2" _above_ the waist. If you wear it lower than that, it won't fit correctly, and it will be too long.
25th August 08, 08:25 PM
That seems a wee bit high to me. He added a quarter inch to my measurement bringing the length to 24 inches. That's an inch above the navel. I don't imagine that's a problem is it? I'm not going to have to keep pushing it down will I?
By orangehaggis in forum Kilt Advice
Last Post: 23rd May 07, 01:26 PM
By Splash_4 in forum How to Accessorize your Kilt
Last Post: 2nd February 07, 06:33 PM
By Frank MacDuffy in forum Kilt Advice
Last Post: 9th December 06, 12:35 PM
By Tiran in forum Kilt Advice
Last Post: 20th February 06, 12:57 PM
By bubba in forum Contemporary Kilt Wear
Last Post: 25th June 04, 06:34 AM
