Results 11 to 20 of 47
    17th June 08
    Topeka, KS
    Quote Originally Posted by Rex_Tremende View Post
    Rubenesque, perhaps, but every body is a work of art.
    What, exactly, are you doing here?
    Rex.
    You can tune a bass drone, but you can't tuna fish.
    3rd January 08
    Illinois, USA
    4 Post(s)
    Quote Originally Posted by Phogfan86 View Post
    Member Order of the Dandelion
    I'm tuning drones before a band competition. Jackson's just so tall that, as Robert says, I really needed a step stool! The guy behind me is holding an electronic tuner, and I'm watching the needle on the tuner while I'm adjusting the drones.
    12th August 07
    Mansfield, Texas
    After loosening the second strap per Robert's suggestion, that seems to have fixed the problem somewhat. I never realized I had the top strap so tight. Thanks all.
    When making my own kilts I need to lift the inner edge of the under apron pleats, so a triangle of double fabric is visible above the edge of the apron and under apron before the waistband is attached. It is something to do with the flare of my hipbones I suspect.
    Without that 'tweek' the pleats roll outwards.
    There might be some fitting trick which could control that errant pleat and make it hang more correctly, but there are limits to what can be achieved when folding fabric around a three dimensional shape.
    Anne the Pleater
    12th August 07
    Mansfield, Texas
    Thank you for all the replies. To answer your question Ted, they are hand-sewn traditional kilts.
    Dan R Porter is offline Membership Revoked for repeated rule violations.
    6th February 08
    hbaha
    I thought you were being kind and pouring your flask into his pipes.
    bricelythgoe is offline Membership Revoked for repeated rule violations.
    7th January 09
    Help!
    Sometimes it's how the kilt is made, and sometimes it's the body of the wearer. As Robert says, wear the second strap loose. That can help. Also, the apron edge should be pressed on a flare from the bottom of the fell, and, if the apron edge is pressed parallel to a tartan stripe, you can steam out the original crease and press in a new one on a smooth flare.
    I would like to get some help with this. I thought bringing up this old thread would be better than starting a new one. I just purchased a B&S casual and I am having this pleat flipping problem. I realized it is just as Barb described. Min is pressed parallel to a tartan stripe. I am not sure how to steam out the original and press in a new one. I have never steamed anything before. Could someone give me some more details about this?
    Brice
    22nd November 07
    US
    Quote Originally Posted by bricekolob View Post
    Brice
    From what kind of fabric is your kilt made: wool, wool blend, other?
    Steeking.
    7th January 09
    Steeking.
    It is wool from Burnetts and Struth.
    Brice
  1. "21st Century Kilts" splits from "Geoffrey (Tailor)"
  2. Replies: 17
  3. SWK - Leatherneck "BOX-PLEAT"!!!
    By Kilted in Maine in forum General Kilt Talk
    Last Post: 12th July 08, 01:07 PM
  4. Henderson (weathered) box pleat with "tweeds"
    By Tattoo Bradley in forum Show us your pics
    Last Post: 27th February 07, 09:11 PM
