Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    8th March 09
    Texas
    I had a Sportskilt without the sewn down pleats, and I was not happy with it at all. So much so, I will not buy another kilt, without sewn down pleats.
    You have alot of options, and if you look at the fact you will wear the kilt more often than you would a single pair of shorts, you could justify the cost equalling a couple pair of shorts.. and any of our casual kilt vendors will be a good option, for a non wool option.
    – Robert Louis Stevenson
    16th September 08
    Charleston SC
    You can look at the Celtic Croft they just released a solid black kilt.
    take a look here Casual Canvas Kilt
    2nd September 09
    Ohio
    I've got two SWK thrifty kilts. (my younger brother wanted a kilt so I bought him two and since he's growing, I went with SW because the price is right. Of course so I could match, a couple of thrifties smuggled themselves in...)
    As far as a knockabout kilt goes they are fine. I wear them regularly although my homemade kilts get more wear simply because they are tailored. The acrylic lays flat and has an "iron" crease to it so the problem of unstitched pleats isn't really much of a problem. There are more pleats and quite a bit more fabric in a SWK thrifty kilt than in a sportkilt. The sport kilt is almost laughable how wide and shallow the pleats are, the SWK thrifty kilt is better in that regard.
    For me the biggest problem with the thrifty is the fact that the whole things is a perfect rectangle, no taper to the "fell" at all (there is a 2-3" fell between two rows of stitching.) Since I am a person with a big difference between my waist and hip measurements the first and last pleat generally lie open, not neatly closed, which is kinda sloppy. But if you're a person with no hips to speak of the thrifty might be fine.
    I'd say it's worth every bit of the $30 especially if it isn't going to fit forever... It is true that you get what you pay for. It isn't a fine tailored garment but it is decent enough to wear most of the time (I wouldn't wear it formally but most informal and walkabout situations it is fine for.) (I wore it to church this morning in a semi-casual way.)
    12th May 04
    Denmark, north of Copenhagen
    Congratulations to your weight loss!
    I, too, should go for the sewn down pleats of the Stillwater Economy kilt. After all the difference between the SWK Thrifty and the economy is no mo more than $23.
    Tell your wife that it shall last twice as long, besides being a better designed kilt up front and that she certainly should be more pleased seeing you in the Economy kilt than the Trifty which might be more questionable as a KILT.
    Finally, the more you pay on your new smaller garments the likelier it is that you shall keep down your weight.
    Good luck!
    Greg
  1. I'm out to purchase my first kilt.
    By Macthenife in forum Kilt Advice
    Last Post: 4th July 09, 08:20 AM
  2. First Kilt Purchase, Could Use Some Advice
    By Glitch in forum Kilt Advice
    Last Post: 27th June 09, 05:46 PM
  3. First Kilt Purchase Advice
    By xdkeys in forum Kilt Advice
    Last Post: 26th May 09, 05:47 PM
  4. First kilt purchase
    By NewKilt in forum Kilt Board Newbie
    Last Post: 12th August 05, 12:18 PM
  5. My first kilt purchase
    By dyfed in forum Kilt Board Newbie
    Last Post: 9th August 05, 09:54 AM
