8th April 10, 05:51 AM
I pretty much agree with what others have said.
I can see why he didn't like the stitching. That style of stitching is more appropriate for saddles and such, but isn't traditional on sporrans. I do all my stitching by hand, too. But I use a much smaller stitch length (double-needle technique) and use a waxed thread that's colored to match the leather. It looks like you were using sinew (or simulated sinew)?
The smaller thread length and matching (or neutral) thread, along with smaller stitch length, will draw attention away from the stitching and toward the tooling. That's what you want to showcase - the tooling!
For several years I hand-made custom leather gun accessories as a hobby. The hand-stitching was by far the longest and most tedious part of the process, but once I had a system it wasn't too bad. I laid out every stitch by hand - making sure that the holes in both pieces matched. Using a wheel won't guarantee that. So I would measure, mark, and punch every stitch hole by hand, using a max stitch length of about 1/8" to 3/16" max. As you can see, the smaller stitch length makes the stitching look cleaner and tidier, while blending into the background and letting the decoration stand out.
While all the advice offered by others is grand, I think making some stitching changes will make the biggest visual difference in the appearance of your sporrans to get to the more traditional look.
8th April 10, 07:30 AM
Thanks you all so much for your encouraging words.
All of this is helpful beyond belief, I'm not quite sure why I waited until AFTER finishing my first sporran to post questions. But then again, I guess problems dont present themselves until after the fact ;-)
I have been using a star wheel, though looking back should probably have used a smaller one, it seems the distance between stitch holes are a bit long to me looking back at it now. As for a "double-needle saddle stitch", I'll be honest, Greek to me. I've ordered a book on stitching leather and hope this will clean my work up greatly. All the stitching I have done so far has just been me literally just figuring it out on my own. Story of my life.
Thank you for teaching me the term "gusset" and "bead trim". Particularly bead trim, I have seem this on several pieces and have been at a loss as to where to start. I know that in itself will improve the appearance of my work by strides.
My next sporran I plan to make black, so the leather and gusset will all be the same color. Admittedly I used leather I had on hand for the gusset of this piece. I didnt really foresee the mixmatch of colors between everything when I started on it. My sinew is natural.... will have to look into finding it in black if it exists.
If not using sinew... what other thread types would you recommend?
Note taken on the width of the hangar, I would have never thought of that. I was also told I need to add D-rings for chains, so that will be another thing to add to my next project.
Thank you all so, so much. Your selfless sharing of knowledge means more than you can imagine.
@ Scottop & Bigkahuna - at the moment, my first several are going directly to the Highland Cattle rancher who supplied me with the fur. But after that... and I have more clean and professional work to offer, I will be more than happy to discuss commissions! I have a LOT of this beautiful highland cattle fur to work with, and am giddy to put my heart into doing these beasts justice through art.
8th April 10, 07:25 AM
Hello Lea,
I agree with most of the above, but would add this - I would wear it!
Welcome to XMarks from the other side of the Atlantic in Norfolk, England.
8th April 10, 07:43 AM
Welcome and Thanks for showing us...
I like your sporran, but probably wouldn't wear it a lot. That is mostly because I wear my kilt as dress and semi-dress. I think it is a fine, rustic design and would be great for daywear, assuming the size is OK. Others have covered that pretty well.
If yours is too small, I am sure someone would welcome it as a belt bag or other ( less standardized ) pouch. And the Child's sporran suggestion is a great one.
Many commercial sporrans have a "double ender" attachment that allows you to clip a sporran strap to it. The double ender is threaded through the loop on the back. I expect many of them get lost over time. I agree, your loop should probably be wider.
At the risk of being crude, we are talking about something hung in front of a man's crotch. Many men like the "surrogate size" effect, meaning bigger is better. But even for those who are secure, it ought to be big enough to carry something, as described above.
Your design is inventive and attractive. I wouldn't worry a lot about making it dressier- plenty of men need interesting daywear sporrans.
8th April 10, 09:14 AM
The hanger which passes through the strap at the back of the sporran is called a 'frog'...but I can see how a pair of D-rings would do the same job. I don't know if there's a particular reason to use a frog vs D-rings, but structurally, a frog would distribute the pull of the sporran along a greater area of the back, whereas D-rings will concentrate the stress. I have absolutely no idea if that has any relevance, tho.
There's no reason not to surround, or frame, the hair on three sides...but let it hang, rather than having it sticking out from the frame.
I agree with the rest of the guys, less is more...as in, it would look really good if the sides were the same color as the front, and the stitching were either black, or color-matched.
As far as pouch size, a larger and deeper pouch would also accommodate more hair on the front...layered, if you will, giving the appearance of longer hair than you're actually using. Don't forget Michael McIntyre's comments at the end of his skit..."and it's gonna be HAIRRRRY!"
Don't lose heart...the colors are great, I like the tan liner with the red cover, the hair is really cool, and there's certainly nothing wrong with your tooling!
-Sean
8th April 10, 11:58 AM
Lea,
I'm hoping to get my first kilt this year - I need to lose weight and gain money - and if I'm ever in the position to pay for a custom sporran, I'm hoping I remember you're a member here, because I want one of these! Sure, modify the size a bit and change the hanger in the back, but I like the look of this!
Good luck, lass,
Brian
8th April 10, 07:41 AM
Very interesting. It's not my style and I can understand most, if not all the critiques. But I think it has something special about it and I think it has a very rustic look minus the studs. Keep it up and let's see how the next one comes out.
8th April 10, 12:46 PM
I have to admit I kind of like it, except for the stitching. I would not worry about the tooling under the flap, just the outer flap. Check out a bunch of other sporrans on eBay or listed for sale on the advertisers on this site for dimensions.
Since you make masks as well, try making a matching mask/sporran set - perfect for a Scottish Halloween!
Keep posting pics!
"You'll find that many of the truths we cling to depend greatly on our own point of view." -Obi Wan Kenobi
8th April 10, 02:15 PM
Thank you guys, thank you thank you thank you. You are all gems.
I actually just got home from a local tanner who has been helping me tan some highland cattle hides I received from the rancher I befriended. So now I have another whole tanned Highland Cattle hide to work with. I've got my work cut out for me though, as he didn't finish it for me... I've got several hours of bristle brushing and sanding the skin side to soften & pretty it up before it will be ready to use.
I've already got another whole hide sitting in the guest room (which might end up as a throw because it is just THAT beautiful)
So.... with that hide above... I've got a LOT of practice ahead of me with these sporrans.
dutchy that is a FANTASTIC idea. I have been planning on making a mask for the rancher using some of his fur for embellishment... but I hadn't thought of doing pairs. ;-)
Thanks again everyone for your advice and well-wishing.
I will post again once I begin sporran # 2.. and will be taking every bit of advice to heart.
Cheers!
8th April 10, 07:51 PM
One of the things I like best about this sporran is the tooling under the flap. When a craftswoman puts that much effort and detail into something that few people will ever see it speaks to the attention she has put into EVERY part of the project. That sort of care was common in the 18th and 19th centuries but, sadly, is not common any more. Look at the works of an old clock or watch, for example. They were as beautiful on the inside as they were on the outside despite the fact that the delicate scroll work or guilloche finishes would rarely, if ever, be seen.
Brian
By tartanswede in forum General Kilt Talk
Last Post: 14th October 09, 03:22 AM
Last Post: 11th September 09, 05:47 AM
By Arlen in forum Miscellaneous Forum
Last Post: 4th June 09, 07:00 PM
By skauwt in forum Kilts in the Media
Last Post: 25th April 09, 06:16 PM
