Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    15th March 10
    Space Coast, FL
    Great tip! I just sent Brandon a PM! Thanks!
    28th March 10
    Australia
    What do you recommend for a PV kilt Rocky?
    6th July 08
    Montgomery Village, Maryland, near Washington, District of Columbia
    You're right Rocky, he was talking about wool. My bad.
    As far as clean a USAK casual in PV, this is what I do.
    Lay kilt flat in bathtub.
    Run enough lukewarm water into the tub to cover the kilt 1-2 inches deep.
    Add a small amount of Woolite or other mild detergent. I repeat, SMALL amount. Due to the teflon coating, soil does not stick to the fabric very strongly, so only a small amount of detergent and gentle swishing is all that is needed to get it off. More soap is just more to rinse out.
    GENTLY swish kilt through the soapy water.
    Drain, refill tub.
    Gently swish again.
    Drain, refill tub. There should be little if any soap left at this point. If there is, remember next time to use less soap.
    Once soap is gone I have a drying rack I stand up in the tub, with the kilt clothes pinned around the top, so the pleat hang straight down. I adjust the hang of the pleats to make sure they are straight by hand if necessary. In a few hours, take kilt off drying rack, and put on or in closet. No ironing, or very minimal ironing is necessary, USAK casuals hold their pleats EXCELLENTLY.
    BTW, the reason I don't lay it flat to dry is I don't have anyplace other than the floor big enough to lay out a kilt, and wet wool or PV is going to raise h3ll with wood floors.
    Geoff Withnell
    Geoff Withnell
    8th February 04
    Machine wash cold (on "delicates" if possible) with like colors
    DO NOT use Fabric Softener
    Lay flat to dry
    Again... straighten out the pleats WHILE THEY'RE DAMP and it will be much easier to iron when dry.
    The mill (that weaves the fabric) says dry cleaning is OK, but I NEVER recommend dry cleaning as the chemicals used tend to take the teflon coating off the fabric.
  1. Tying garters...an alternative to the STM method
    By wildrover in forum How to Accessorize your Kilt
    Last Post: 19th July 10, 11:33 AM
  2. 2nd Kilt: SWK Std vs USAK Cas vs USAK SemiTrad
    By LaphroaigQCFan in forum Kilt Advice
    Last Post: 18th November 09, 10:38 AM
  3. Construction Method/Modern Kilt
    By Mr.Charles Anthony in forum Professional Kiltmakers Hints and Tips
    Last Post: 10th September 08, 01:26 PM
  4. Is dry cleaning the only method for a kilt?
    By ardchoille in forum Kilt Advice
    Last Post: 30th August 07, 02:03 PM
  5. Relaxtion method
    By Raphael in forum Miscellaneous Forum
    Last Post: 30th March 07, 08:58 AM
