2nd February 11, 07:57 AM
 Originally Posted by Hothir Ethelnor
Well I probably cheated and didn't mantain perfect diamonds.
I knit them flat and simply added a stitch at each end as I went along for the increases.
Then when they get stitched together, the seam at the back will not have a perfect pattern in it although it will still be symmetrical.
Yeah, that's part of the problem. I've also seen what appears, to my inexperienced eye, to be a fudging of the shape of the diamonds--where the bottom corner is three or four stitches wide rather than a true corner one stitch wide.
Also, you can block the hose and the knitting will stretch but then you risk seeing skin through the hose if the patterns aren't right or the knitting dense enough.
2nd February 11, 04:59 PM
According to the proprieter of my local yarn shop, knitting round was a continental method while the british knit flat and made a seam. So from that your method is nothing to apologize about, rather it would be the more historical. I should seach the forum for any other opinions on this
Elf
-atr: New Zealand proverb
2nd February 11, 05:47 PM
It's hard to tell from the web site why the book costs so much, because you can't see how many pages it has or what the nature of the illustrations are. If the authors chose to do a full-color book inside from cover to cover, it would have been a very expensive book just for the printing.
Book pages are normally printed in "signatures" - a set of pages ganged together and printed on big sheets and basically cut apart and bound - rather than as individual pages. If you want to have color illustrations scattered throughout a book, you have no choice but to print every page on a color press. You can cut the cost of printing down dramatically if you cluster all the color illustrations into one signature (depending on the printer, that would typically be multiples of 8 or 16 consecutive pages) and print the entire rest of the book in black and white.
Anyway, that might explain it. On the other hand, maybe they just want to make money selling the book.
And remember that anyone selling a book wholesale will be expected to give a retailer up to a 40-50% discount on the list cost of the book, so someone factors that into the retail selling price when setting the cost of a book. If their book is color inside cover to cover, and they did a small print run, and they need to make even a couple of dollars on the wholesale price of the book.....that could be a pretty expensive book.
3rd February 11, 10:09 AM
It's might' nigh impossible to make tartan/Argyll hose in the round. Trust me.
The increases up the seam will not make perfect diamonds, and in fact they're usually kind of funny-looking, but they should be symmetrical.
--dbh
3rd February 11, 11:36 AM
I think I am correct in saying that the author also produces knitting kits for dancers hose, and I presume that this book is based on the same instructions that come in those kits. As an owner of one of those kits I am not sure I would recommend this book for someone trying to make hose for adult men; as a few posts have hinted shaping for an adult male's calf is not easy – this is less of an issue for children/women who the book is probably aimed at.
The real difficulty with knitting argyll hose is yarn; this has to be dyed to suit the tartan and marled yarn must be spun. Double thread can be attempted but again the colour match will be difficult, and very light weight yarn will have to be used to give the required stitch count, which will limit options.
It is certainly not unknown for commercial hose to have visible seams at the rear, and not just budget offerings. To maintain a perfect pattern the tension and needle size have to be altered, although this of course has limits and certain leg shapes probably can't be catered for without visible decreases.
As to the price of argyll hose, well these can be obtained fully bespoke for around 150 dollars. The amount of work that goes into these means that's a pretty fair price in my opinion. It really depends if you consider the value of you own time in comparison – the book, plus yarn, plus 10 or 20 or 100 hours to knit...
3rd February 11, 05:23 PM
This may be apocryphal, but I was told that companies such as Kilkeel and Henderson, who knit hose to match Dalgliesh dress tartans, actually use the same yarn that Dalgliesh uses so that the hose match their tartans exactly. Does anyone know if this is the case? That's what I was told at one point.
3rd February 11, 05:28 PM
You may be right as to the author and the connection to the kits...which I know are designed for small legs--young dancers.
But that said, I know from recent email conversations with the author that the book, which I think is fairly recent, covers how to adjust for large men's calves. I asked that specific question. And in the most recent response the implication is that you can also adjust the patterns to make the backseam symmetrical.
Marled yarn is a problem but marled yarn is not used on kilts and it doesn't have to be used on hose either. This was one of the issues my wife had to deal with when she made my first pair of hose. I actually like the looks of two colours in place of marling better than the marled yarn itself.
I have another pair coming in MacQueen colors that is similarly done. This time however she figured that doubling the yarn in the calf area would not only make the calf larger without disturbing the pattern but also denser so that the yarn won't stretch open. I've tried one of the pair on and it seems to be larger and denser than my previous pair.
First pair... SuperWash Merino blend fingering yarn.
3rd February 11, 01:31 PM
Don't know if this helps, but all of my daughter's Highland hose have been what's called "fully fashioned", i.e., with a seam up the back. They've all been custom knit in the UK (by Henderson) and, in fact, the fully fashioned hose were actually more expensive than those that weren't.
The pic below shows how they dealt with the diamonds, and her calf definitely required shaping. The diamonds basically merge where the hose tapers. I think they look fine done that way.
10th March 11, 01:27 PM
Fully-fashioned, superior construction
"Fully fashioned" is a knitting term. It means that each piece is knitted to the shape that will be used in the garment. Fully fashioned garments may be seamless or seamed.
I cannot tell from the photo if the back of the hose has a true seam (sewn of two bound edges). The hose may have been knitted seamlessly, and what shows as a seam is where the knitted-in decreases were worked from the calf down to the ankle.
When a garment is not fully fashioned, the pieces are cut from a bolt of knitted fabric, then the edges of the cut pieces are serged to prevent ravelling, and the pieces are sewn together.
Fully-fashioning is the traditional way to knit by hand. It can be done with machine knitting, and that requires much more attention and skill than making a cut and sewn garment.
Fully-fashioning is by far the superior construction method. Since the edges of each piece are bound off in knitting, a garment made this way will last much longer than one that is cut and sewn.
As is usual, one gets what one pays for.
2nd February 11, 09:39 AM
BTW, my wife says that using a merino blend fingering yarn only takes about two skeins per major colour (rakers take an insignificant amount). She gets her yarn from KnitPicks and it costs roughly $2.00 per skein.
So, unless they are having the marled yarn custom-made (hard to find in suitable colours)...ie. red and black marling or green and black marling...there isn't that much advantage to the "bonus yarn" offer. Not that it's not a good deal but rather that it probably shouldn't make the difference in whether you see the book as worth having or not.
By BLHS209 in forum The Library
Last Post: 8th November 10, 04:22 AM
By Mikilt in forum The Tartan Place
Last Post: 23rd October 10, 03:51 PM
By Paul in forum How to Accessorize your Kilt
Last Post: 10th October 09, 03:58 AM
By kilted Kiwi2 in forum General Kilt Talk
Last Post: 5th April 06, 09:39 PM
