Results 11 to 12 of 12
Threaded View
    19th July 09
    Central Illinois
    Stag handled Dirk-Progress
    Greetings all...It has been a while since I posted on this project (couldn't find the original thread)...I have made a bit of progress on my "downhill without breaks" stag handle dirk and roe deer handle by-pieces project.
    The main dirk blade is permanently mounted into the grip-tang is 3/4" tapered to 3/8", with about 1" of threaded end to recieve the nut. I was forced to countersink a 1" long nut INTO the steel pommel cap, but it worked. Peined and ground flush, then re-peined...it's solid. I used two allen head bolts threaded into the crown to hold the pommel position, too. I am working on test pieces to figure out hot soldering-I am going to fill the fuller gaps (and guard gaps) at the entry of blade to guard with solder, once I figure it out. Original thought was to braze, but the stabilizer material I used inside of the antler is only rated for around 600 degrees F...Brazing requires more heat-that, and I did not want to wreck the temper of the blade. It's looking like one of those blades of convienence...not exactly pretty, but very durable.
    The fork pictured is one of a pair I picked up trolling antique shops. From 1750's, I figured it would be as close as I could come to a good original, and given the shape of this one's handle, I have no problem dismantleing and mounting into the roe deer antler shown.
    The assembled spoon is a test model-combo copper pipe and one antler from a deer I hit with my Jeep. Oh, and a bit of sinew-ran into an issue using a wide kerf saw blade. For the dirk by-spoon, it will be a brass bowl and a jewler's saw inlet (that copper gets HOT when eating oatmeal and soup!).
    Also, does anyone here know a smith that could bang out a real steel sword scabbard throat with locket and tip? Given the dirk above is intended to appear to be made of a broken backsword, I was hoping to be able to have a scabbard that resembles an equally altered scabbard of the same era. Might be a year before I am in scabbard mode, so....
    A pitchfork is a polearm too!
  1. *Functional* Stag-Handled Sgian?
    By Dale Seago in forum How to Accessorize your Kilt
    Last Post: 13th June 11, 08:28 AM
  2. Red stag handle dirk, and historical question(s)
    By Mark E. in forum DIY Showroom
    Last Post: 7th April 11, 10:13 AM
  3. White Handled Dirk
    By Taygrd in forum DIY Showroom
    Last Post: 28th November 10, 10:51 PM
  4. Stag Handled Dirk
    Last Post: 27th November 10, 08:04 AM
  5. Stag Handled Projects
    By Kilted Carver in forum DIY Showroom
    Last Post: 6th November 08, 02:31 PM
