View Poll Results: Where do you wear the top of your kilt?
- Voters
- 100. You may not vote on this poll
31st March 13, 05:40 PM
I think one issue that I have is this:
When I'm standing, it doesn't feel "so high up" on my torso, but when I sit down, the front rides up, and it makes me feel like my grandfather (you know, the guy who's belt is right up under his armpits).
I really am appreciating the feedback.
Again, it's not where the bottom is -- that will never change. It's how HIGH the kilt needs to be from there. And I guess mine just needs to be right where the pros measured me to be wearing it -- about 2 1/2 inches above my navel.
31st March 13, 05:42 PM
Depending on the style of kilt and the maker, all of the above could apply to me.
Gentleman of Substance
31st March 13, 06:26 PM
 Originally Posted by Father Bill
It's Easter Sunday. We should give thanks!
Good reply Reverand.
31st March 13, 06:28 PM
Since I don't actually own any of my kilts, just on loan from the bands, the only thing I can do for mine, is to use the bottom hem, and the top lays where it must. That's why my answer used the bottom hem. I hope I didn't take your question off target.
31st March 13, 06:49 PM
#15
I wear my traditional style kilts at my navel. This is because I have a long torso, and with my kilt there the bottom falls it's right at my knee. However with my contemporary kilt, it's at my belt line (pants waist), but that's where it's designed to sit.
So to answer your question, it depends.
-Nik
31st March 13, 08:53 PM
#16
Well AJ, in reality the navel is a secondary marker for what is referred to as your "natural waist" the point where your body bends when you lean to either side. Depending on how you are built, that point may be at, above, or below you navel. As others have stated, it typically lies somewhere around the level of the navel, but where YOU bend may different then where I do. Make sense? So if the kilt is already made to fit you, it will be important to know where the kilt maker measured you so that the kilt sits where it was designed to sit. Hopefully that too ends up so that the bottom of the kilt sits above your knee!
Reason: Late nite, punkshuashun. and speling
31st March 13, 10:00 PM
#17
I usually wear mine around my waist. But sometimes, when I've had too much to drink, I wear it around my head.
Seriously, though- I like to get mine made military cut, meaning about 1.5 to 2 inches higher than normal. I wear mine year round, so when it gets cold and windy in winter, I can pull it down to cover my knees. So I like mine a little longer than most.
31st March 13, 10:03 PM
#18
I put "at my navel", but to be honest, it depends upon the kilt. I have one tailor made kilt - all the others are pre-loved. I also have one ex-mil Black Watch, so that sits much higher. My natural drop is 23", and I adjust the fit of the kilt to match the length - I like my kilt to sit 1" above the centre of the knee cap.
"The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it" (Terry Pratchett).
1st April 13, 12:02 AM
#19
To properly answer your question I would need to ask you one in return.
When and how is your kilt made?
Prior to about 10 years ago almost all kilts were made in the traditional style. The top strap was designed to snug into your natural waist.
To find your natural waist - open your hand and place your thumb at your side just under your ribs. Then bend into your thumb. Do you feel a hollow there? That is your natural waist.
A traditional style kilt tapers down from your hips to your waist, This is where the top strap is. The kilt then flares back out. The smallest part of the kilt is at the top strap.
Here is my traditional style kilt.
You can plainly see that it is smallest at the level of the top strap. That will cinch into your natural waist. This kilt is designed to be worn up at about kidney level. The very top of kilt covers my short ribs in the back.
Another feature of a kilt is that the bottom of the Fell, or the bottom of where the pleats are sewn down, should be at the level of the widest part of your hips and butt.
If your kilt is made this way, and you wear the top straps at your natural waist, the hem should be right at the top of your kneecap.
(The old thing about kneeling on the floor is actually an old kiltmaker trick. As the top of the kilt is 2" above the top strap,,,, if you have the customer kneel and measure from the natural waist down to the floor,,,,,then make that the total length of the kilt,,,because the top strap is 2" lower it will raise the whole kilt up 2" and the hem will be at the top of the kneecap.)
About 10 years ago everything changed in the kilt world. With the pressures of high labor cost combined with the influx of less expensive kilts from the middle east, and factor in the Utilikilt that was designed to be worn down at low rise, kiltmakers have been finding ways to cut costs to stay competitive.
It is not uncommon for the kilts coming out of some of the most respected named houses, not to have the flair above the top strap.
Lacking this flair the smallest part of the kilt is now up at the waistband. This is now the part that will try to fit into the natural waist. So the entire kilt falls down about two inches.
This causes the bottom of the Fell to be below the butt causing the stage curtain effect you see in many kilts. It also causes the hem to drop to the middle or bottom of the knee.
As kiltmakers we have customers come in every day who do not know that the kilt is an older style garment and is supposed to be worn up high. They only know blue jeans so assume that a kilt is worn at the same level.
So, do you have a traditional style kilt?
To see what type of kilt you have and how it should be worn, fold the kilt in half so it looks like the pic above. Does your kilt have the flair? If so put the kilt on and cinch the top straps into your natural waist.
Then, reach around back and slide your hand up the pleats till you reach where they are sewn down. Is this at the same level as the the widest part of your butt? If it is, your kilt is at the height it was designed to fit.
(BTW this widest part of the hips and butt is also right at your hip joint. Where your leg pivots at your pelvis.) (Well, if your a guy that is.)
Now that you have your kilt fitting correctly at the natural waist and Fell, kneel down in front of a full length mirror. Don't bend over. Look straight into the mirror with your back straight. Is the hem about 2" off the ground? If so you have a perfectly fitted traditional style kilt.
If you want me to try to describe how a modern kilt is different, from the ground up, from a traditional, I can, but it would be a post longer than this one.
1st April 13, 02:15 AM
#20
I personally find if I'm wearing "off the peg" kilts, they sit about 2ish inches above my navel, but I have short legs and a long torso. Having said that, I am ordering a tank from Paul Henry in the next few weeks which will only be an inch or so shorter. I find the support of the kilt on my lower back quite nice, due to the fact that I have back problems, and if that makes my kilt height "old fashioned" I'm ok with that (anything's good with cocktails involved).
I can't understand why people are frightened by new ideas. I'm frightened by old ones. John Cage
