Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    4th November 16
    US
    Quote Originally Posted by Derekc5555 View Post
    How long do you think I should let it soak in the coffee/tea? A few hours? days? Weeks? Also would a diluted brown dye also work?
    I was about to suggest that, using a diluted dye. I dyed a British army dress jacket black, and the instructions on Rit Studio website (from someone who dyed a suit purple for her son's Joker costume ) advised using two bottles of dye versus only one for cotton, rayon, linen, etc. So maybe if you tried using, say, a third of a bottle of brown dye? Better to have it come out too weak and have to do it again than too dark.
    Oh, I almost forgot...the instructions are here: https://www.ritstudio.com/2015/10/26/joker-cosume/ Only I found that I didn't have to use the fabric refresher let alone putting it in the dryer (which I would certainly not advise with a belted plaid), as the only vinegar smell I noticed was when I re-pressed the bottom edges with a press cloth sprayed with vinegar water...and even that smell dissipated on its own in less than an hour.
  2. The Following User Says 'Aye' to Dollander For This Useful Post:
    29th September 16
    Rohnert Park, CA, Usa
    Thanks Dollander, I appreciate the info.
    A tea or coffee wash should only take a little while to be effective. An hour at most - but you would need a large container - a bath perhaps? I'd advise wetting the fabric first, then putting it into the colouring liquid, be it tea coffee or a real dye, to get even take up.
    It was not uncommon for patchwork to be put into a dye in order to make the various different materials blend together. Tinting everything brown, pink or blue - whatever was to hand made the finished item look more coherent, rather than made of whatever was to hand.
    Anne the Pleater
  5. #4
    29th September 16
    Anne the Pleater
    Thank you Anne. Do you recommend coffee staining or actual dye?
