10th June 08, 07:46 PM
The X-Marks Clan plant.
The Dandelion makes sense as our clan plant, as like us, like it or not, we're everywhere.
10th June 08, 09:00 PM
The Mighty Dandelion...
Muckle kudos to the X-Marks crew for choosing such an apropos plant badge!
Here's tae us, Whas like us... Deil the Yin!
10th August 09, 12:50 PM
Bump up post.
Does any one have any other technical notes on how to prepare plant bage? Are there general guidelines when placing a plant badge? I would hate to be that guy with a whole bush on a bonnet.
10th August 09, 02:19 PM
 Originally Posted by NCMC
Bump up post.
I'd say take a look at photos of others or paintings and I'm sure you will get the idea, it's not like you want to go walking around with a tree behind your clan badge. I wear a silk dandelion behind the XMarks Badge. My clan buckler is a kilt pin on my clan tartan.
10th August 09, 02:32 PM
Bump up post.
Just pick/pluck/cut a sprig/branch/handful of the plant and stick it behind your crest badge on your bonnet. It shouldn't be too difficult to place it between the cockade and the bonnet itself.
Not difficult at all! If it is, you are trying too hard.
10th August 09, 03:04 PM
Four XMarkers on a kilt night in Preston, England. No hats as we are indoors, but we are still wearing our dandelions.
At the Harpenden Highland Gathering with a gentleman from Kenya called Peter Myfatherhasthebiggestpotatoes. Note - hat and lapel.
:ootd:
10th August 09, 06:26 PM
 Originally Posted by Deil the Yin
Would anyone have a suggestion from preserving it, or rather making it permanently wearable? I thought maybe painting it and then covering it in some kind of clear lacquer or some such?
Thoroughly dry the sprig, usually by hanging it, cut side up, on a bit of thread (for decorative purposes, use a color that matches the stem, if you can) in a dry area. Alternately, one can use a dehydrator, a low temp oven, or out in the sun, if you have a good are to do so. If you don't dry it, it WILL rot.
Then, using said thread, dip the sprig into clear epoxy and remove allowing excess to drip off. To make it easy to keep on, you may want to add a small pin to the bottom end of the sprig, or a tie tack pin while the epoxy is still liquid (thick).
Worked for me with my Cumin sprig.
Death before Dishonor -- Nothing before Coffee
Nihil curo de ista tua stulta superstitione
10th August 09, 07:23 PM
Pictures look good, thanks for the tip.
2nd February 10, 08:34 PM
Boxwood is another clan plant badge.
3rd February 10, 06:09 AM
Hey all,
Here is a list of clans with their plant badges. I can not confirm the authenticity of this list but the data appears to match the few clans that I know about.
http://www.scottish-wedding-dreams.com/clan-plants.html
