Results 21 to 30 of 41
    I hope this helps to answer some of the questions you all have.
    First, I made a mistake when I posted the pleat reveal. It is actually 1/2" at the bottom of the Fell. This is a kilt for a very thin person. The waist is only 30"-32". So that may be throwing some of you off.
    It is also very heavy fabric so there may be a visual illusion happening also.
    The area of the pleat cut-outs was pretty well frayed when I got the kilt. Please remember that this is a military loaner kilt and has been used and abused by generations of young soldiers.
    Now, on the the questions.
    How much fabric needs to be left to re-sew the pleats I have no real idea. I would estimate 6-10 threads of good cloth should be sufficient. Please remember that when worn there should be almost no stress on the pleat stitching.
    This is what I have been trying to stress to everyone and why I started this thread in the first place. A Traditional Kilt has re-enforcements behind the Fell that take up the stress.
    Today we are so used to seeing kilts where there is nothing inside the kilt. Where the pleats are just sewn down. All the stress of moving is transferred to the pleat stitching and if that fails the kilt fails. If there is a liner it is more for show than to cover and hide the interfacings.
    This Kilt was made by a competent Kiltmaker. Were they a Master? Well, I have no way of knowing. But it is evident from the construction that they did not have Barb's book when they learned their trade. The methods used are completely different. There are many ways to make a kilt. Some good and some not so good. And some are just different.
    The one thing that I have learned about kiltmaking is that it is not the outside of the kilt that is important to the construction it is the inside. The stuff you do inside will allow the outside to look good and hang well but if you skip or omit the interfacings and stabilizers the kilt will fail. Or at least it will not look as good as one with the internal construction.
    The next step I did was baste the entire kilt. I re-shaped the apron edges and put in 5 rows of pleat basting. I did the pleat basting more to make the thing manageable to move around the shop. The basting will also be more to hold everything in its relative position than to set everything perfectly for pressing.
    The next step is to re-stitch the Fell back together. As anyone who has made their own kilt will know this is hours of hand stitching. Over and over till all the pleats are stitched.
    22nd November 07
    US
    Thanks Wizard of BC! This has been a very interesting and helpful thread.
    13th March 05
    Wow, Steve - I recognize that kilt! I wore it 36 years ago! It was in better shape then.
    10th March 07
    I've been following this but wanted to find out a bit more before I commented.
    From what I can see you're doing a fantastic job so far. And I'm surprised to see a Loaner Kilt that has lasted so long. It's been well worn and it looks like you are going to help it get a few more years.
    Well done, Steve.
    I had a chance to spend some time working on the Military Kilts so I thought I would post an update.
    When I took to old worn waistband off I found that this kilt did indeed originally have a reverse pleat. So I thought what the heck, I've gone this far I might as well put it back in.
    The first thing I have to do is re-establish the under-apron right side taper.
    Here you can see my method of doing that. Note that I am using a trick from my yacht design days. The curved line is laid out with a flexible batten and some lead weights called 'ducks'.
    Here is a shot from a different angle showing the amount of apron taper and the curve.
    Once the aprons are basted and pressed I was able to finish the basting.
    Now that everything is back in its proper alignment it is starting to look like a kilt again.
    Here is what the inside looks like at this stage.
    Even though the Fell stitches are missing it doesn't look too bad.
    The next step will be to re-stitch all the pleats in the Fell. Most of the stitches are loose and done with a very large yarn like stuff. So wish me luck as I begin the long process of stitching.
    30th November 05
    Mountains of Utah U.S.A.
    Seeing the first pic I could not contemplate reconstruction.
    Now seeing this pic I can see it was the cutting of the extra material along the back that I was looking at in the first set of pictures. Very nice job Steve.
    Not even the same kilt but much nicer.
    Will your Client be surprised, You bet Ch'a.
    MrBill
    Listen to kpcw.org
    Every other Saturday 1-4 PM
    Oh wow - Kilt Resurection Unlimited.
    That is looking good - though all that mare's nest of threads would worry me.
    Human hair conditioner is quite useful for smoothing wool - more particularly knitted things, but also woven, if it has had the scales lifted by hot water. It can sometimes assist in loosening the fibres enough to allow the garment to be stretched out to what it was, or at least closer to it.
    Another good thing is vinegar, as wool 'prefers' to be slightly acidic rather than in the alkaline state which detergent leaves it. 'Old wives' used to add a drop of white vinegar to the final rinse for wool. For a kilt it might require half a cup, or even more for a tank.
    15th October 07
    NE Ohio
    Wow... gotta say that it looks completely different. Good luck on the rest of it. Can't wait to see the finished results.
    14th December 05
    Coeur d Alene, ID
    Its A L I V E !!!!!!!!!!!!!!!
    1st March 04
    Steve, I really take my hat off to you, as I would to any kiltmaker or anyone attempting to make their own kilt (not the same thing!), for having taken this one on in the first place. That you have made such fine progress is to be applauded and, I believe, indicates that a competent engineer is undertaking this restoration. Very well done!
    I still cannot get my head around the washing, in water, of a traditional, woollen kilt - Woolite or no Woolite! Maybe it is because neither of the washing machines I have ever owned has had a cold, or even cool, wash setting. Obviously it can be done, but I would never risk it.
    Cannot wait to see your finished handiwork.
    Take care,
    Ham.
  1. Military Box Pleate Canvas Kilt?
    By Bugbear in forum Contemporary Kilt Wear
    Last Post: 14th March 08, 08:20 AM
  2. A Military box pleat kilt
    By JohnH in forum DIY Showroom
    Last Post: 6th August 07, 11:09 AM
  3. Kilt pins from military awards.
    By Richland in forum How to Accessorize your Kilt
    Last Post: 17th May 06, 08:51 PM
  4. how to wear military kilt
    By mcnice in forum Kilt Advice
    Last Post: 16th October 04, 02:30 AM
  5. Military surplus kilt
    By Raphael in forum Contemporary Kilt Wear
    Last Post: 15th May 04, 05:55 PM
