Originally Posted by
A_Hay!
The next step would be to use the beveler to depress the leather next to the lines you have cut. Nighthawk's tooling tutorial shows some pictures of how this is done. You want the thick lines of the design to stand out, so always bevel the outside of the line with the deepest part of the depression closest to the thick band. Where two lines cross, you bevel across the one that goes under the one on top. Overlap the beveler strokes so that you don't see each individual stroke. Your goal is to leave a smooth trench. I overlap my beveler strokes by about half and then move on. If the trench is still a little rough, you can use the stylus with the spoon end to rub along the trench and smooth the marks out.
Tom
I should have included that! I know my pictures aren't the best. I need to redo those. When I update my tooling tutorial, I'll mention that. Thanks for pointing out that deficiency, Tom.
