7th September 07, 10:26 PM
ardchoille, you seem to be the most versed. What do you suggest? I know there is a lower powered version of ubuntu, xbuntu or somethign like that. any other ideas?
8th September 07, 02:42 AM
Xubuntu is simply Ubuntu with xfce as its default desktop (ubuntu, kubuntu, edubuntu, nubuntu, flubuntu and xubuntu all use the same repos anyway). Xfce runs quite well on older hardware and it's much faster than either KDE or gnome. Give xubuntu a try. If that fails your needs, try using a window manager instead of a full desktop. The fluxbox and WindowMaker window managers (in the repos) are super fast and light on system resources.. not to mention beautiful and easy to use.
10th September 07, 06:15 AM
I have been using slackware for at least 10 years
10th September 07, 10:38 AM
before I go and install linux here on my desktop, does anyone know how I can get all my outlook express contacts and saved emails into evolution on my laptop? Or possibly is there another linux email program with import options? Evolution is ok, but I like outlook express better, and would like one more like it
10th September 07, 10:48 AM
I'm not sure what Outlook Express looks like, since I haven't used Windows in 7 years, but many Linux distros come with the KDE desktop environment and KDE includes kmail and kaddressbook (both are components of the Kontact PIM) and I love them. Kubuntu uses KDE as its default desktop, and includes kmail and kkaddressbook. Kaddressbook has an import wizard that can import contacts from many Windows programs and formats. Kmail has an import wizard and I just noticed that it can import email messages from Outlook Express. Here's a screenshot:
So, if you decide to use KDE as your desktop, you should be all set, I'm not sure about the gnome desktop because I haven't used it much recently. I know that knoppix, MEPIS and Mandriva also use the KDE desktop.. and Mandriva is the best out of those three in my opinion. Knoppix and MEPIS are live cd's (they run from cd drive and ram without the need to install to the hard drive). I'll bet there are tons of Linux distros which use KDE or have it available for installation.
10th September 07, 11:22 AM
10th September 07, 08:11 PM
I just had an interesting idea. Does anyone have a kilt theme for either windows or Linux? Not just a tartan background, but everything down to the windows, the panels, etc?
10th September 07, 08:51 PM
I don't know how gnome works, but in KDE this would require someone to know how to program because you would need to code the style and window decoration theme. I've thought about it but it's too much for me to learn just to come up with a style and windeco theme. I do know that you can get swatches of tartans and make wallpaper out of them using the gimp. The login screen and KDE splash screen are easy enough to create so you could use those swatches there too.. but, again, a screen saver would require coding.
I've searched http://art.gnome.org and http://www.kde-look.org but haven't been able to find anything tartan/kilt related.
12th September 07, 11:17 AM
A managed to Xubuntu up and running on my desktop yesterday. What a difference! Installation when pretty smooth, though I had a bit of problems getting it format and repartition the hard drive. But i rebooted the computer and tried again and everything went smooth. The installation itself went without a hitch. The OS runs very smooth and VERY fast. It runs much faster than windows xp did, even fresh out of the box. The only software issue I had came from Automatrix 2. there was some wierd issue with frostwire and java for some reason, and kept freeze automatix up. It took me an hour or two to figure out a way around the problem. What I had to end up doing was clearing a setting in terminal then, I installed java sun 5 with synpac, to make sure I had the java issue covered, then I used synpac instead of automatrix to install frostwire. After that everything worked great and automatrix works fine now. What a difference now though, The speed is so much faster, everything from boot up to my internet connection. Im thinking about putting this version of linux on my laptop too. It seems to run better than the Ubuntu I have on the laptop. Or possibly, can I just install Xfce over what I have on there now? would that make t run like the desktop?
12th September 07, 01:25 PM
Automatix is dangerous.
You should never use automatix.. it's a very dangerous app. I sit in #kubuntu and #ubuntu on the freenode network and I help newbies. One of the things I see is automatix trashing lots of computers and people come into those channels to get it fixed. Often the best thing they can do is reinstall their Linux distro and never use automatix again. Automatix does dangerous things and should be avoided. It may work fine now, but I can almost guarantee that you will have problems later and those problems are difficult to track and solve. Automatix doesn't do anything that you can't do for yourself anyway. Stay away from automatix, it's bad news.
Have a look at this review of automatix which was done by a debian/ubuntu developer and you'll see why automatix is dangerous. The best thing you can do right now is reinstall your Linux OS and warn others about automatix.
