Results 31 to 40 of 41
    Ah Hamish, this kilt was not washed in a machine but in my bathtub.
    I would NEVER put a wool garment in a machine.
    I simply put about 4 inches of water in the tub and mixed in the Woolite. Then dropped the kilt in and let it soak for about 15 to 30 min.
    A gentle squeezing to work the fabric and watch the dirt come out.
    Then pull the plug and let the water drain as you gently squeeze the excess water from the kilt and re-fill the tub with rinse water.
    When the water no longer shows signs of dirt I drain the tub and leave the kilt laying in the bottom to drain for a few minutes. Then roll it in a towel and gently step on it to remove as much water as I can.
    I them hang the kilt on as many hangers as will fit and onto a line it goes. In the summer I find a kilt will drip dry in about six hours.
    With a kilt like this that no longer has any pleat creases or if the creases are badly pressed there is no need to baste prior to washing.
    In fact in this case basting would have prevented the accumulated dirt deep in the pleats from being worked out of all the nooks and crannies.
    1st March 04
    Steve,
    Thank you SO much for explaining the process. As I said, it can very obviously be done but, even with your clear instructions to hand, I really do not think I could ever risk washing any of my woollen kilts - I would be too afraid of shrinkage! When I think of all the lambswool sweaters and pure wool hose that I have hand washed across the years, I feel confident in stating that, almost without exception, every item has shrunk, even if only slightly, after a number of washings. For that reason, I do not wear 100% wool nowadays, apart from my kilts (!), opting instead for wool + man-made fibre blends.
    How fortunate that everyone takes differing views on matters such as this.
    Good Luck, and thank you again.
    Take care,
    Ham.
    You are absolutely correct Hamish. All garments shrink over time. It is the agitation that does it. And Wool is the worse. In days past, before washing machines were such a large part of our households you could find sock stretchers, sweater blocks, and scarf rollers in every laundry room.
    The secret to washing Wool is COLD water and little to no agitation. I simply squeeze the fabric.
    The surface of a wool fiber when looked at under magnification looks very similar to a pine cone. The application of heat softens and opens the plates. Agitation such as that in a washing machine or dryer then pushes the the plates into each other shortening the length of the fiber and making it thicker. This is known as 'Fulling'. The mats in cat fur and dreadlocks are formed in a similar process of locking the microscopic scales together.
    This is also how felt is produced.
    Once 'Fulled' Wool fibers are permanently shortened and thickened.
    But we have washed clothes for as long as clothing has been around and with proper care a Wool Kilt will survive repeated hand washing. There are some who only hand wash Wool Kilts. It is thought that the chemicals used in Dry Cleaning will, over time, remove the lanolin from the Wool.
    16th May 08
    forgotten
    Quote Originally Posted by Hamish View Post
    I still cannot get my head around the washing, in water, of a traditional, woollen kilt - Woolite or no Woolite! Maybe it is because neither of the washing machines I have ever owned has had a cold, or even cool, wash setting. Obviously it can be done, but I would never risk it.
    Ham if I read Steve's fist post correctly he washed the kilt in water but not in the washing machine, but in the bath tub. Using the bath tub allows for very gentle agitation of the water.
    Drain the water and gently squeeze the water out and then refill the tub until the water comes out clean
    I hope I have not misread Steve's post.
    And, having been handed dirty kilts to alter, I completely sympathize with Steve for having washed it before doing anything else. The sheer stench of a dirty kilt that hasn't been well taken care of is, shall we say, off-putting....
    1st March 04
    Quote Originally Posted by Friday View Post
    You are quite right, Friday; Steve made no mention of a washing machine. I am afraid I assumed that he had used one because, over the years here at X Marks, folks have often referred to setting their machines to a cold wash cycle when washing kilts - a facility that, as I stated, neither of the washing machines I have ever owned, have had, and I've never used a drier.
    Thanks all the same for your contribution.
    Take care,
    Ham.
    10th March 07
    Steve... wow!!! It actually looks like a Kilt, again.
    I hope you're getting paid well for this!
  1. Military Box Pleate Canvas Kilt?
    By Bugbear in forum Contemporary Kilt Wear
    Last Post: 14th March 08, 08:20 AM
  2. A Military box pleat kilt
    By JohnH in forum DIY Showroom
    Last Post: 6th August 07, 11:09 AM
  3. Kilt pins from military awards.
    By Richland in forum How to Accessorize your Kilt
    Last Post: 17th May 06, 08:51 PM
  4. how to wear military kilt
    By mcnice in forum Kilt Advice
    Last Post: 16th October 04, 02:30 AM
  5. Military surplus kilt
    By Raphael in forum Contemporary Kilt Wear
    Last Post: 15th May 04, 05:55 PM
