6th March 09, 03:24 PM
"Flipping" pleat
Hello all. It's been a few months since I've posted, but I just noticed something. The first pleat to the left of the top apron (the first pleat just over your left leg) has a tendency to flip up a bit on all of my kilts. Does that happen to anyone else? Is there a way around it or is that normal? It's odd that I never noticed it before.
6th March 09, 03:32 PM
A couple of things. If your hip strap is too tight this may be the problem. Loosen it off a notch
Try adjusting the kilt so that the pleat is a touch more to the back, you may have the kilt not centred properly. It doesn't take much, just a half inch or so.
6th March 09, 03:35 PM
Bryan, you need to tell us which kind of kilts you have; whether they are hand sewn traditional kilts, custom, or off the rac.
6th March 09, 04:18 PM
Also, some utility style kilts have a tendency for pleat curl. There hasn't been a lot of talk about it in a long time but it was a huge topic a few years ago. Search for pleat curl and you will probably pull up several threads about it.
6th March 09, 04:26 PM
Sometimes it's how the kilt is made, and sometimes it's the body of the wearer. As Robert says, wear the second strap loose. That can help. Also, the apron edge should be pressed on a flare from the bottom of the fell, and, if the apron edge is pressed parallel to a tartan stripe, you can steam out the original crease and press in a new one on a smooth flare.
Having said all that, if you have muscular or chubby thighs, you'll likely just have to live with it. A kilt is made assuming that the biggest dimension around is at the buttocks. If you have muscular thighs (or fat on the outside of your thigh tops, if you're a woman), the kilt won't be quite big enough to go around the front and/or sides of your thighs, and the first pleat opens up a little. Nothing you can really do about it, frankly. Voice of experience here - I have chubby thighs, and the first pleat (first two, actually) on my kilt always flips open (see photo below):
6th March 09, 05:01 PM
Rubenesque, perhaps, but every body is a work of art. What, exactly, are you doing here?
Rex.
6th March 09, 05:27 PM
Looks like she's tuning one of the drones.
12th March 09, 07:36 AM
yep !
Robert Amyot-MacKinnon
6th March 09, 05:40 PM
Rex.
Wishing she had a step stool......
6th March 09, 06:28 PM
I was just thinking about this today. My first two pleats like to flip up like that and I thought it was just the cheap kilts I have been getting. I just got my USAK from Rocky and it does the same thing. Guess there is not much I can do.
By S.G. in forum General Kilt Talk
By Kilted in Maine in forum General Kilt Talk
Last Post: 12th July 08, 01:07 PM
By Tattoo Bradley in forum Show us your pics
Last Post: 27th February 07, 09:11 PM
