28th August 09, 01:13 AM
 Originally Posted by gilmore
Actually, there is a way to tell how far back in time your and your close YDNA's matches' most recent common ancestor lived.
Family Tree DNA has a software tool that will give you an estimate as to the probability of the number of generations that separate you from each of your matches. "...FTDNATiP™ calculator which takes into account our new University of Arizona mutation rate study information. " http://www.familytreedna.com/my-ftdn...ftdna-tip.aspx
It is expressed like this, an example of one of my close matches and me:
"In comparing 37 markers, the probability that Mr. XXX and Mr. AAA shared a common ancestor within the last...
generation is 2.72%
2 generations is 9.72%
3 generations is 19.9%
4 generations is 31.56%
5 generations is 43.32%
6 generations is 54.25%
7 generations is 63.84%
8 generations is 71.93%
9 generations is 78.53%
10 generations is 83.79%
11 generations is 87.89%
12 generations is 91.05%
13 generations is 93.44%
14 generations is 95.22%
15 generations is 96.55%
16 generations is 97.52%
17 generations is 98.23%
18 generations is 98.74%
19 generations is 99.11%
20 generations is 99.37%
21 generations is 99.56%
22 generations is 99.69%
23 generations is 99.78%
24 generations is 99.85%."
We can see that the 50th percentile is crossed between five and six generations. Therefore, it becomes more likely than not---or probable--- that our most recent common ancestor was at least five or six generations ago. The number of years in a generation for men varies from culture to culture, from society to society, but the usually accepted figure is 27 years, so we see that that was some 135 to 162 years ago, or around the period starting in 1847 and ending in 1874. Thus, our most recent common male ancestor probably lived in the early 19th century or earlier. While this fact is not in itself dispositive of a whole lot, it can be an important clue. And that is what much of genealogical research is, following clues until we arrive at harder and harder facts, and get a more and more conclusive picture of who and where our ancestors were, and what they were doing.
In this case, the other man knows from his research when his patrilineal ancestor came to America from Europe, and which city he came from. This tells me where and within what period of time it might be useful for me to do further research, starting with my oldest documented patrlineal ancestor I am sure of, and working backward.
Also, YDNA testing can sometimes show with amazing exactitude---with precision that increases as more and more men test--- the geographic location where the mutation of the marker(s) that distinguishes their YDNA from others' occurred, and how long ago it occurred. In other words, it is now sometimes possible to say, e.g., that "It is more probable than not that Mr X, Mr Y and Mr Z descend from a common male ancestor who lived on the island of Harris 250-300 years ago."
I have to say that as far as I know, the estimates of mutation rate, especially in "coding" and there fore naturally selected regions of the genome, is a topic of pretty hot debate right now. I'd be chary of pinning too many statements of *Truth* on estimates.
Also, and I don't know the answer to this.... exactly WHICH regions of the Y chromosome are sequenced to provide the ancestry information. There's still a huge amount of debate over the spontaneous mutation rate, but whatever the case, estimates are in the range of a single mutation per 100 - 500 generations.
Here's a very low estimate, I know the second author on this paper..
http://www.ncbi.nlm.nih.gov/pubmed/14691732
Here's a stunningly high estimate
http://dienekes.blogspot.com/2009/08...tion-rate.html
Four base substitutions in thirteen generations? Wow, that's four point mutations in 250 years.. I haven't read the actual paper, I don't know how they actually got tissue from 13 generations back...
It's also pretty clear that the Y chromosome does not mutate evenly across all loci.
http://www.sciencedirect.com/science...cfeb20edae7dc1
In summary, again, I'd be chary of putting too much weight on the TIMING of things, as "determined" by yDNA testing.
However, one thing you said is spot-on, for sure... "with precision that increases as more and more men test"
I'd also like to very slightly edit another phrase that you wrote, to make a point...
sometimes...yes. Sometimes, no.
I quite like the way you phrase this...
It's clear that you're talking about estimates, and understand that generation times can vary. As long as the discussion is about "estimates" I'm good to go!
And you make a good point. As the cumulative data set widens, the accuracy is only going to get better....though it will still always be an estimate.
28th August 09, 12:53 AM
While I agree that DNA testing is best used when it supplements the paper trail, it's obvious that YDNA testing can show ancestry linking a man to some one whose other descendents are part of Clan X---or who was himself a clansman.
We are beginning to confuse biology with culture. DNA can outline the former quite well. The latter is a trickier thing. What a clan is---or more acurately, what a clan was---is determined societally, not gentically, though of course genetics play a part. (And we won't even get into clan associations.)
Of course there is a great difference between saying "My YDNA shows that I am a direct patrilineal descendant of Somerled, (even though we are pure Italian as far back as we can trace it)" and saying "I am a member of the clan MacDonald."
I'm afraid I must take exception to this. ""My YDNA shows that I am a direct patrilineal descendant of Somerled"
I'm afraid not. Even if we had copies of Master Somerled's yDNA to sequence, even a base-for base exact match between our hypothetical persons y chromosome, and Master Somerled's Y chromosome, that does not PROVE that our friend is descended from Master Somerled.
It only indicates to a high probability that he is descended. In fact it could possibly be that our hypothetical fellow is descended from someone else, who just SO HAPPENS to have the same Y Chromosome. Let's pretend that this person is Master Ballantrae.
How could two people have the exact same Y chromosome?
Well, for one explanation, Master Somerled and Master Ballantrae are brothers. Perhaps they're identical twins. Our client could quite easily be descended from Master Ballantrae, and not from Master Somerled at all.
That's just one example, of several I could give you.
27th August 09, 12:45 PM
I hope I may ask a question - I have my fathers line back to George Corliss - first Corliss across the pond in the mid 1600's and to his father somewhere in Britain. Knowing this, what else can Y DNA testing tell me?
28th August 09, 01:45 AM
I think your paper trail is pretty freaking good, if you really have that information documented.
Phil, that's almost 350 years. That's amazing.
If you really wanted to pursue this route, I'd research mtDNA, instead and take a look at Moms side of the family. mtDNA has a significantly higher spontaneous mutation rate than chromosomal DNA, though estimates of that rate are all over the map! However, since mutations accumulate more rapidly, there are a lot more haplotypes and haplogroups and you can get more specific information than with yDNA testing. NOte that not all haplogroups of mtDNA mutate at the same rate.
That clock don't click the same, over the entire genome.
I'd be chary of pinning too much the timing of things. Any results that you get back will be ESTIMATES and if you keep that in mind, you might find out something useful.
28th August 09, 12:24 PM
 Originally Posted by Alan H
I think your paper trail is pretty freaking good, if you really have that information documented...
snip...
snip...
Thanks Alan - yeah, there are a few advantages of having a super rare last name (Corliss). I did most of the work on dad's side but I have had a couple of hard core genealogists look it over and they concur. Mom's side (Paskett)is also solid back to the early 1600s thanks to a few generations of hard working Paskett genealogists. I can't imagine doing this before computers, those folks must have had the patience of a saint.
I will certainly look into mtDNA - thanks for the advice.
Phil.
28th August 09, 12:35 PM
Phil.
Honestly, Phil, you've got a paper trail on your mothers side that goes back to the 1600's as well? No kidding?
Phil, you're done. DONE. See my previous post. mtDNA testing will give you suggestions about general areas, and general haplotypes that mom might be connected to. It will NOT tell you that your ancestor in 1537 lived in Paris, on 445 Rue De Genome Street.
28th August 09, 12:41 PM
Phil, you're done. DONE...
I suspected that Alan, but I see so much about DNA in genealogy I wondered just what I may be missing.
As an aside, I have been lucky enough to stand on the same streets as my ancestors, sit in the same churches where they were married and buried some 500 years ago. It is a surprisingly moving and powerful experience.
I hope some day everyone who does genealogical work can share it.
28th August 09, 01:20 AM
Wow, the things we can get into, here on X Marks. I NEVER thought I'd have a discussion on Y chromosome mutation rate estimates!
28th August 09, 01:34 AM
Just saw this...pretty interesting, regarding the co-inheritance of both your surname and your particular y chromosome haplotype..
http://www.ncbi.nlm.nih.gov/pubmed/19204044?ordinalpos=1&itool=EntrezSystem2.PEntrez. Pubmed.Pubmed_ResultsPanel.Pubmed_DiscoveryPanel.P ubmed_Discovery_PMC&linkpos=3&log$=citedinpmcartic les&logdbfrom=pubmed
Upshot is, depending on your name, the degree of correlation between inheriting your surname, and inheriting your haplotype varies HUGELY....with the more rare names being passed on more reliably than the more common ones.
In other words, depending on someones surname, to formulate a pool of individuals against which to compare your haplotype, based on the name, might not necessarily be the most accurate thing to do, especially if you have a very common name.
28th August 09, 01:48 AM
One thing about what Gilmore is saying on the clans and genetics... The clan chiefship or the normal passing on of the title of chief is absolutely one-hundred percent based on genetics; in other words, an offspring or genetic relative off to the side. Without a chief, there is no clan.
I interrogated MacMillan of Rathdown on this point a while back, and he assured me this was the case. All other clan related things are matters of loilty to the chief and are not required to be geneticly based.
It would be interesting to see how the genetic relations pan out in the chiefs if it were possible to follow back the path of the DNA, since there was no way of being sure until recent times.
On the other hand, it might open a few cans of worms; I know it would in my family.
By brandycr in forum Miscellaneous Forum
Last Post: 2nd May 07, 05:22 PM
By switchblade5984 in forum Miscellaneous Forum
Last Post: 1st June 06, 04:16 PM
By Graham in forum General Celtic Music Talk
Last Post: 8th September 05, 04:44 PM
By Graham in forum Contemporary Kilt Wear
Last Post: 28th August 05, 12:21 PM
By akaussie in forum General Kilt Talk
Last Post: 18th January 05, 02:26 AM
