29th September 19, 11:36 AM
‘Flare’ in pleats
I’ve been reading lots on this site and ‘The Art of Kiltmaking’ and have been casting a critical eye on my new kilt. I notice that the pleats ‘flare’ (i.e. get slightly wider) from the bottom of the fell to the bottom of the kilt. Is it preferable that they are completely parallel between fell and lower edge? It seems that geometry would suggest that they should be parallel to avoid the ‘shower curtain’ waviness. Does the inclusion of the slight flare indicate a different (perhaps older) tradition in kiltmaking?
One thing I haven’t looked at yet is to see whether there is a corresponding decrease in the depth of pleat in the same direction - I must have a look.
John
29th September 19, 11:53 AM
To better understand what you are describing, may we ask if you have a photo please.
30th September 19, 02:54 AM
30th September 19, 10:41 AM
Yes, if you lay a kilt out on a table with the Fell Area flat, the pleats will always splay outwards.
To press a kilt, or to evaluate the accuracy of the pleating, you must lift the Fell Area and sort of "tuck' the pleats up until the horizontal lines are all straight..
But more importatly in your case, is the alignment of the lines in the Tartan to the pleat edge.
Find a pleat where a prominent Tartan line is near the creased edge up near the bottom of The Fell Area. Follow that line and see if it maintains the same distance away from the crease all the way down the pleat.
30th September 19, 06:40 PM
That’s some lovely work, Steve.
The Following User Says 'Aye' to BrianHK For This Useful Post:
2nd October 19, 04:01 AM
But more importantly in your case, is the alignment of the lines in the Tartan to the pleat edge.
I’ve laid the kilt out carefully, as you suggest and, of course, you’re dead right; the pleat edges are pretty much parallel to the lines in the tartan (and, therefore, each other). Phew, what a relief .
2nd October 19, 08:42 AM
And when the kilt is worn, do the pleats flare then?
2nd October 19, 09:42 AM
As far as I can tell, it hangs properly at the back (peering over my shoulder and squinting in a mirror) My wife tells me it looks OK.
(I should be more positive - I think it looks pretty good!)
2nd October 19, 11:54 AM
3rd October 19, 08:14 AM
Oh my - what is it called when the pulse does a little flutter at the sight of a 'pleat shot'?
I'm hoping for a high percentage of 'normal's - all things considered.....
Anne the Pleater
