22nd January 09, 09:50 AM
Why no belt with PC / Vest?
I have learned and read that you should NOT wear a belt with a PC and Vest, but I have yet to hear why.
I've heard that a belt with an Argyle jacket is ok, but with a PC is not ok.
Could someone explain why some accessories are seen as ok, and others are not?
I am talking traditional attire. As we have covered in many other threads, once you understand the "guidelines" you can choose to ignore them or not at your own risk.
I just want to know why a belt and a PC/Vest is seen as taboo.
Thanks!
22nd January 09, 09:59 AM
Ayin,
Here are the two big reasons
(1) A belt makes an unsightly bulge under a waistcoat / vest spoiling its lines
(2) The large waist plate of a kilt belt will stick partially out from under a kilt cut waistcoat or vest making the waistcoat / vest look too short and ill fitting
22nd January 09, 11:28 AM
The Prince Charlie is almost always worn with a 3 button waistcoat, which should not be worn with a belt, for the reasons Jamie enumerates above.
I've also seen Prince Charlies worn with a cummerbund, which also looks nice, and which also would prohibit the wearing of a belt, for the same reasons.
Basically, if you are wearing anything that's going to cover your waist (top of the kilt), like a vest or a cummerbund, leave the belt at home.
That being said, I see no reason why you couldn't wear the Prince Charlie jacket with a belt, sans waistcoat/cummerbund. It's just not normally worn that way.
22nd January 09, 11:31 AM
I was confused in slightly the same way. I had memorized that you should never wear a PC without a waistcoat, so no belt with PC. I repeted that in a post, then I was told that one may wear a cummerbund with a PC , but no belt with cummerbund just like the waistcoat. It was Matt who told me that.
Then I was told that it is absoluteley fine to wear a PC without a waistcoat, and in it's place, a dress belt with waistplate. I asked around, and I didn't really get an answer from the traditionalists on that; sometimes you have to stirr things up to get a clear answer.
Then I was told that one should not wear a cummerbund with a PC... So it's back to the waistcoat with the PC.
Believe me I am all for understanding why things are done, beyond "because I said so" and "that's just the way it is," but you usually have to get the traditionalists talking to each other about it to find those answers.
22nd January 09, 11:41 AM
By way of comparison, would you wear a cummerbund *and* waistcoat with a tux? Probably not....
22nd January 09, 01:06 PM
The way I understand it, and I could be wrong, is one waist-item only. So one of a) belt, b) cummerbund, or c) waistcoat. Adding more than one, and certainly all three, would just look ridiculous.
22nd January 09, 01:08 PM
Exactly.
Same principle applies to belt *or* suspenders/braces, but not both at once.
22nd January 09, 01:12 PM
Bravo, you have it!
Only one item from the waist accessory column when ordering your formal outfit.
As I have a sporran with a fancy cantle that matches a waist plate I could see wearing it with my formal jacket (sans vest).
22nd January 09, 01:30 PM
I think that is nicely stated and makes sense. Thanks!
22nd January 09, 01:36 PM
Ayin,
Also remember in a martini
It is either 1 olive or 2 cocktail onions!
By runewolf in forum How to Accessorize your Kilt
Last Post: 5th January 09, 04:38 PM
By Harold Cannon in forum How to Accessorize your Kilt
Last Post: 2nd July 08, 06:10 AM
By Scotexan21 in forum Show us your pics
Last Post: 23rd January 07, 03:57 PM
By JockEleven in forum Kilt Advice
Last Post: 14th September 04, 01:37 AM
By kilted in KC in forum How to Accessorize your Kilt
Last Post: 17th June 04, 09:32 PM
