Results 1 to 10 of 27
    yoippari is offline Oops, it seems this member needs to update their email address
    6th August 05
    Salem, OR
    casual kilts, work kilts, and nice kilts
    I have a stillwater standard in black stewart, I don't think I would wear this to any formal event because it is a little light weight and I know it is not a nice kilt. Besides the untapered waist is unflattering. I have a Newsome kilt in a family tartan on order that I don't exactly know where to wear to. I don't know if I should wear it to school, if I should wear it to the family reunion in december (we have one every december), or if I should keep it in the closet until I get a prince charlie, broges, and a black tie.
    So basicly, what kilts should be worn where? Would you wear a stillwater the same place as a utilikilt, or the same place you would a tailored kilt?
    Graham's Avatar
    Graham is offline Oops, it seems this member needs to update their email address
    4th February 04
    Tasmania, Australia
    Good questions!
    Personally, I divide my kilts into casual and traditional, regardless of whether they are plain or tartan.
    I keep the casuals, mostly 4 yard kilts, for casual wear and the tradtionals, or 8 yarders for formal. This is only because generally speaking, the 8 yarders are better quality.
    Other factors determining my choice would be the weather (wool or PV), colour matching, ie. if I have a jacket that would go better with a certain tartan kilt, then I'll match then up.
    Overall, most kilts are flexible enough to be worn in any situation, that's the wonder of kilts. What matters more is how you accessorise the kilt, wear a T shirt for casual or collar and tie for formal.
    M. A. C. Newsome is offline
    INACTIVE
    Contributing Tartan Historian
    26th January 05
    Western NC
    A good hand tailored kilt in a worsted wool should be adaptable to all occasions. In other words, what makes it casual or formal will be how you accessorize it, not the kilt itself.
    Graham made the distinction between 4 yard and 8 yard kilts, which a lot of people do. One reason why is that most major kilt firms that offer a 4 yard kilt are machine stitching them and offering them as a "causal kilt" which implies that they cannot be worn for formal wear.
    But if the kilt is made from quality material (such as a worsted wool) and is hand tailored, it can be just as formal as any 8 yard kilt. The reason I mention this is because I don't want you to get the impression that the 4 yard box pleated kilts like the ones I make are just for casual wear. I got married in one!
    It all comes down to the accessories.
    Now, on the other hand, many of the contemporary kilt styles, such as Utilikilts, or kilts made from a non-woolen material, really are *designed* for casual wear, and will look out of place if worn to a formal occasion, especially one in which a traditional kilt is expected.
    Aye,
    Matt
    8th February 04
    Quote Originally Posted by M. A. C. Newsome
    I agree with most things Matt says, but I don't agree with this completely. There are a few contemporary kilt companies that DO look "traditional enough" to wear to formal events... If you take a FK (inch wide pleats model) and get it without the buttons, it's a sharp "traditional looking" solid kilt. If you take a Poly Viscose kilt and sew it up properly, give it straps and buckles and fringe, it can be (to the untrained eye) pretty darn close to a wool kilt. It's not until you inspect it close up (and touch it) that you know it's not wool. We've had many customers get married in our Semi Traditional model. We've had several pipers buy our Semi Traditional b/c it's cooler and much more cost effective than wool. When they're marching alongside of other pipers in a parade, you can't pick out the PV vs. the wool.
    Would I try to pass off our Casual model (or a Bearkilt or Sportkilt) for a "Kilt to get married in"? No. Are they formal enough to pipe in? No. Can we go to the store in them? Yup... that's what they were designed for.
    I'm just saying that SOME "alternative material" kilts are found to be dressy enough to wear to weddings and / or pipe in.
    INACTIVE
    26th January 05
    Western NC
    Rocky has a good point. Take Lochcarron's "casual kilts." They are machine stitched from four yards of cloth. But they are made from the same woolen tartan as any of their other kilts. They are knife pleated, have the same leather straps and buckles. In other words, the only difference between it and one of their normal kilts is that it has half as much cloth (and so fewer pleats) and is machine stitched. From a distance, most people would not notice a big difference.
    I wouldn't recommend getting one of these in light weight cloth, but in a medium or heavy weight wool it does quite well. And wear it with a nice black Argyle jacket or even a Prince Charlie, with ghillie brouges and a formal sporran, and you'll look quite nice. If you had the choice between this and a hand tailored kilt, I'd say wear your hand tailored one -- but if this was all you had, you'd be fine.
    Now the more you start to deviate from the standard, the less likely it is that you'd want to wear it to a formal event. A machine stitched kilt, made from only four yards of a light weight acrylic cloth, with a smaller than usual sett, designed to sit on the hips, etc., etc., would not work. In other words, if the kilt is designed specifically to be casual wear, I wouldn't wear it outside of that context.
    But I still stand by my earlier statement that a mark of a good kilt is that it can be worn casually or formally, depending on the accessories.
    Aye,
    Matt
    8th February 04
    Aye,
    Matt
    Matt... I think we're close in thoughts and on the other small points, we can agree to disagree.
    The point I was trying to make above... the MATERIAL ALONE does not (IMHO) dictate whether a kilt is "dressy enough" to wear to a formal event. It's a combination of the material AND the way it's made. I wasn't aware that Lochcarron's 4 yarders were made to sit on the hips. That's too low to wear with an Argyl Jkt. Conversely, if a PV or Solid color Cotton blend (or whatever) kilt is sewn up "traditionally" so that it gives the appearance of a "traditional wool kilt", it would be more than acceptable to dress up for a GOOD percentage of the kilt wearing public. He11... UK had (or has) a "Tuxedo Model" kilt. I think that saying THAT isn't dressy enough to wear to a formal event (with jacket, bowtie, etc) might raise an eyebrow or two.
    Also, as Iain points out, people posting on XMARKS generally know a GOOD DEAL more than the average Joe on the street. There are differing schools of thought on what is "dressy enough" to wear with a jacket and tie and this is where we'll "agree to disagree".
    I'm sure that MANY people (of the "old school") will INSIST that ONLY an 8 yard wool kilt worn with ALL of the proper accessories would be acceptable enough to wear at a wedding or funeral. If that's how they feel, that's FINE for them! They will look FANTASTIC at all times! Personally, I would only wear an 8 yard wool kilt to a formal event (because I have 7 of them) and have all of the other things to complete the outfit.
    However, with the average "beginner" to "moderate" kilt wearer (who may not have $1500 + to spend on a complete top of the line outfit), the more affordable PV version of an 8 yard wool kilt is a VERY viable option for dress occasions and most times, attendees of the event will not even KNOW it's not wool, much less a "Handsewn 8 yard kilt".
    On a slight tangent...
    This is what debates should be... a friendly exchange of ideas which can be boiled down to figure out where the differences lie. At that point, one of the people may change their mind. If not, then we HAPPILY agree to disagree and know that this is what makes freedom of speech great! My hat's off to you Matt.
    Brasilikilt's Avatar
    Brasilikilt is offline Oops, it seems this member needs to update their email address
    29th February 04
    Portland, Oregon
    Here's my 2 cents
    I agree whole heartedly with much of what has been said.
    I think everyone here in this thread has given good answers and put solid reasoning behind them.
    I personally think that you can take pretty much any "normal" kilt be it a tartan or plain and *make* it work for formal or casual by matching it up with the proper clothing and accoutrements.
    I think that a Utilikilt (although it might not look as nice as a traditional woolen 8 yarder) when matched up with a nice shirt, jacket, tie etc can look *very* sharp!
    Take these guys for instanceignore the guy's white basketball shoes)
    As for my new USA Kilt (thanks again Rocky!) or Nubia's good ol' Brasilikilt I would feel quite comfortable wearing it in a formal setting because it's a KILT, plain and simple......I've read many posts on this forum about people stopping to ask a guy in his kilt if he's a bagpiper, or going to some kind of formal event. A kilt to a lot of people says "He must be dressing up to go somewhere nice."
    Just the other day, some of the little neighbor girls were asking me why I was wearing my kilt, before I could answer their grandmother said "He must be going to some formal event" I simply explained that I wear it because I like it.
    It's very safe to say that we on this forum know much more about kilts than your average person off the streets.
    Most people don't know much, if anything about the differences between 4 yard, 8 yard, polyvicose or worsted wool.....most people wouldn't know to look and see if your kilt was fastened with belts and buckles, velcro or snaps
    I mean......If someone were to make a snooty remark, or downtalks to me about wearing my kilt to a formal event, I can say with confidence "I had my kilt custom tailored.....what about your pants?"
    Even the more modestly priced kilts are still expensive well crafted garments which are (for the most part) custom tailored to fit the people ordering them......
    To me that says you're willing to put in the extra money and effort to look really nice........anywhere you go!
    A kilt was never designed for someone to look poor, slovenly or disheveled.
    A kilt was made for the person wearing it to proudly distinguish themselves as an individual who has class and isn't worried about what anyone else thinks!
    I hope that despite all my rambling I was able to make a few points you all can identify with :-)
    When you're kilted, you're a cut above the rest!
    Iain
    Wear your kilt proudly, but carry a big stick
    17th July 05
    Alpharetta, Georgia USA
    You will feel comfortable wearing your family tartan kilt at the family reunion. Depending on the dress mode for the event, you will look sharp in the family tartan kilt with a polo shirt, a dress shirt with an open collar or with a tie along with your kilt hose, flashes, belt and sporran.
    Your family members will appreciate you wearing the tartan, for most of them that will be the first time they have seen it. Who knows you may win some kilt converts there at the reunion. (don't forget to tell them about X-Marks)
    Next year there may be several of you there kilted. I can't think of a more appropriate place to wear a kilt in your family tartan.
    Jim
    8th February 04
    Quote Originally Posted by yoippari
    OK Yoippari,
    To answer your ORIGINAL question (sorry we sort of highjacked the thread)...
    I would wear a casual (any tartan kilt you can buy for $150 or under is a casual kilt) kilt anywhere I would comfortably wear jeans.
    I would wear a "more traditional looking" kilt (USAK Semi Trad or 8 yard Wool kilts or even some nice 4 yard wool kilts or a 4 yard box pleated kilt) ANYWHERE... You can wear it with a jacket and tie OR with a t-shirt and boots.
    It's easier to DRESS DOWN a "traditional looking" kilt than it is to DRESS UP a casual kilt.
    I've worn both my Stillwater Standard Black Watch and my USA Kilts philabeg....not the "tadtitional", but the philabeg, with ties and a kilt jacket and a semi-dress sporran to the San Francisco Symphony and gotten nice comments. I think that was stretching things a bit for the philabeg, but what the heck.
    I wore a Bear Kilt, four yard in his Formal Cut with a kilt jacket and tie that coordinated with the kilt...same semi-formal sporran to a wedding and fit right in with a mess 'o MacFarlanes, many of which who were kilted in tradtional wool kilts.
    I've warn my black Stillwater Standard to a few dresier functions, but haven't matched it with a jacket, yet. What I won't do is wear my caramel-colored canvas kilt to a formal function. It's just not the right thing...it's a knockaround.
