Results 1 to 10 of 14
    18th September 04
    Rochester, NY
    Looking at argyles, but what length?
    I'm seriously considering getting a black argyl from J.H. Higgins , but they have a choice of long, extra-long, regular and short. Now I'm quite sure I don't want the long or extra long, but how am I supposed to know which length to choose from my other possible choices?
    Also, would you reccomend the straight, PC, or gauntlet sleeve style. I kinda like the PC look.
    has anyone here ever purchased this jacket from Higgins? Any comments on qulaity? It seems reasonable, and is within my budget, for the most part.
    14th February 04
    Little Chute, Wisconsin
    Take a trip to a mens clothing shop and try on some jackets to find out what size fits best, short, regular or long.
    18th September 04
    Rochester, NY
    Now, excuse my ignorance, but they are referring to the length of the overall jacket, and not the sleeves, right?
    14th February 04
    It referres to sleeve length. The length of the jacket is proportional to the sleeve length and depends on the style and cut.
    2nd August 05
    Prescott, Arizona
    I believe it's both.
    I was measured by a tailor who told me 48R, but the sleeves were way too long. So either I have a long body or short arms or both.
    I still don't know what I should do!
    2nd April 05
    Smyrna, Tennessee, USA
    Quote Originally Posted by Avonlea22
    Yes and no. I wear a 48L (L= Long). If I was to put on a 48 regular or a short, the sleeves would be too short. The length of the jacket would also be shorter. It would probably fit me throughout the chest,but not anywear else.
    Kilt jackets, be it PC or Argyll, are cut shorter than a spoartcoat. That way it does not cover the pleats. There is also a "cut out" in the front to allow room for the sporran.
    You mentioned in an earlier post that you had a tuxedo jacket, If it fits OK, you could probably use its size as a guide.
    However, kilt jackets are usually a tighter fit, so you might have to go one size smaller. Talk with sales people, they can give you proper measurements you need for the best fitting jacket.
    18th September 04
    Rochester, NY
    I do have a tux jacket, and it fits well, but I'm curently on a weight loss program, so within a few months, I will hopefully be smaller (would not order the jacket until that time).
    Do finer department stores sell argyle "type" jackets? If I were to go in and get measures, if I told them I'm ordering a jacket over the internet, and I have a choice between regular, long, etc., would they have the knowledge to tell me what I need, or do I just geuss?
    This doesn't seem to be an easy task when you can't just go try it on.
    2nd April 05
    If only they did. Unfortnately, if you don't have a local higland wear shop nearby,your only option is internet/mail order.
    As for proper measurement, you can always go to a formal wear shop, and asked to be sized for jacket with tails. They are probably the closest thing to the cut of a kilt jacket in the way they fit.
    macwilkin is offline
    Retired Forum Moderator
    Forum Historian
    22nd June 04
    tailor...
    Any good tailor should be able to take a look at the measuring instructions provided by Higgins and then measure you.
    T.
