Results 1 to 9 of 9
    21st October 05
    Pace ,FL USA
    Amerikilt question
    For those of you that have Amerikilts ...what is the fastening system used on these. I am most likely going to order one at the end of the month and was wondering if there is any adjustment to them. I am between sizes now and losing some weight but would hate to order the smaller one and find it doesn't fit. Also how hard would it be to alter one if I get the bigger size then lose weight.
    John
    24th July 05
    Narberth, PA
    The fastening system is snaps on the front and under apron and a piece of velcro at the waist, so there really isn't a lot of room to grow or fade in them. I have lost a bit of weight since I bought mine and have been able to move over the velcro a bit. I also wear it a little higher than when I bought it to make it fit better and pull the belt a little tighter. If you are looking to drop a one waist size you could be ok, a couple of sizes would be difficult to adjust. I love my AK it's comfortable as hell and so far pretty durable.
    I have four AKs and they seem to have some flexibility. Snap system is similar to UK. Since the snaps are lower it allows the waist to flex some. Don't know that I've ever had a good connect on the Velcro big as I am. But the belt covers any play.
    I have pics of my AmeriKilts in my gallery if that helps you any.
    20th February 06
    Falmouth, Maine, USA
    Amerikilt
    I'm wearing my AK at work as I type this. The six snap fastening system is similar to UK, but in vertical pattern and not tapered, like UK. I find the actual snaps a bit smaller and lighter weight and each snap seems to have a tighter purchase. I unsnap each more carefully than on the UK, since I'm more concerned about their pulling out from the fabric, but that may be unfounded.
    The Velcro closure on the waistband, which at first seemed “cheesy,” now seems to make sense. It allows for a better fit and adjustability if your waistline changes.
    A word about belt loops. I have to commend AK on a narrower set of loops—2” rather than the 3”. Fits most belts better without the rollover effect.
    Good luck!
    NewKilt's Avatar
    NewKilt is offline Oops, it seems this member needs to update their email address
    3rd August 05
    Jefferson City, Missouri
    Quote Originally Posted by longshadows
    Good luck!
    I have 5 AK's and would agree that there is some adjustability. I've dropped about a waist size and still have a good fit. What I do on the snaps is to grip the edge of the snaps to open them rather than pull on the material. I agree about the 2" belt loops. I have the AK black belt and it fits great with these loops - no rollover at all.
    Also, depending on which AK you have, there is quite a bit of weight difference. I have the tan, denim, corduroy, khaki, and olive. The tan and denim are light weight, the corduroy and khaki are considerably heavier, the olive falls about in the middle as far as weight when compared with the others. Can't comment on the weight of the black and brown since I don't have them. I really like the look and feel of the AK's, and even the lighter weight tan and denim are very durable.
    One thing to be aware of - these kilts are combed cotton twill, the pleats will get creases and wrinkles so make sure you do a good sweep before sitting to minimize this. One exception, I have yet to get a single wrinkle in the pleats of the chestnut brown corduroy.
    Darrell
    23rd November 05
    Easton , PA
    I have a black Micro-Fiber Amerikilt, and though it does wrinkle, it hangs out pretty well.
    I agree with some of the other comments here, but I like the AmeriKilt as a casual kilt.
    Mark Dockendorf
    Left on the Right Coast
    Quote Originally Posted by NewKilt
    ...Also, depending on which AK you have, there is quite a bit of weight difference. I have the tan, denim, corduroy, khaki, and olive. The tan and denim are light weight, the corduroy and khaki are considerably heavier, the olive falls about in the middle as far as weight when compared with the others.... One thing to be aware of - these kilts are combed cotton twill, the pleats will get creases and wrinkles so make sure you do a good sweep before sitting to minimize this.Darrell
    Thanks for the review! I had been interested in the Forest or Olive AK, now I think I will go for the khaki (looking for something appropriate for hiking).
