Results 1 to 10 of 26
Thread: Sgian Don't
    4th June 04
    Bolton, Massachusetts
    Sgian Don't
    I've long wanted to build a sgian "don't" bottle opener, but hadn't been able to find a suitable bottle opener. I finally decided to start with a great opener, and shape it to my needs. I drew out the shape, and had my brother-in-law cut it at his shop. After cutting he also ground down the edges a bit, since they were very sharp. I had the holes drilled to provide more binding for the epoxy.
    The handle is walnut, the two ends are cherry, with brass sandwiched in between. Since I'm working in my tiny city apartment and don't have access to a workshop, I couldn't take one piece of walnut and split it along the grain. Instead I used a sheet of craft wood from the local art store. As such, the grain won't match along the edges, but I'm okay with that. This is as thick as the wood comes, which works out to be perfect when put together. I have a tiny bench vise which I used to hold the pieces in order to chisel out a channel for the tang (sorry, no photos, since I was getting into the work and didn't think to stop for documentation).
    I glued up all the pieces with two-part epoxy and clamped it while it dried. I let it dry overnight before going at it with a file this morning.
    After filing I worked up through 400 grit sandpaper. It's so smoooooth..... I buffed it with a rag, and then hit it with some mineral oil. Wow! It was just a piece of wood before, but after the oil it lit right up. Bam.
    This'll be fun to bring to parties.
    Andrew.
    6th December 06
    Michigan
    Looks good!! Nice job!
    CactusJack is offline Membership Revoked for repeated rule violations.
    20th June 07
    Very nice.
    10th March 07
    Niiice. A very interesting shape. Looks great.
    Nice work Andrew!
    24th November 06
    Oregon
    Beautiful!
    Just curious, where did you get the brass bits?
    Moosedog
    16th July 06
    Sierra Vista, Arizona, USA
    A classic design! Great minds think alike. Happy bottle opening.
    21st August 07
    San Clamente Ca
    Nice work it looks great.
    4th June 04
    Quote Originally Posted by Moosedog View Post
    Beautiful!
    Moosedog
    Same place I got the wood - the hobby section of my art store. It was a big long strip of brass which I cut up with my Dremel tool.
    Andrew.
    BEEDEE's Avatar
    BEEDEE is offline
    8th January 07
    Tinopai, New Zealand
    Nice work!
    Brian
  1. Could Have Been a Sgian
    By O'Neille in forum DIY Showroom
    Last Post: 30th December 07, 09:42 AM
  2. New Sgian dubh & Sgian Brew and a very public thanks
  3. Another Sgian Don't
    By Arlen in forum DIY Showroom
    Last Post: 8th August 07, 02:15 PM
  4. My New Sgian
    By McMurdo in forum How to Accessorize your Kilt
    Last Post: 7th August 07, 03:49 AM
  5. Sgian dhu II
    By David Thornton in forum How to Accessorize your Kilt
    Last Post: 19th April 06, 04:58 PM
