Results 1 to 10 of 14
    1st June 07
    St. Louis, MO
    Repleating an old kilt
    Well, I have decided to make another kilt.
    After careful consideration of what to do with my ill-pleated but most loved first kilt, String came up with the idea of ripping the fell out and repleating it.
    I liked this idea, and since I had a scrap of free time today, I decided to rip the seams out.
    For the pictures:
    This is the kilt in question, as worn this weekend. See this post for that and other photos.
    These are the pleats, before ripping. I can follow the pattern that was trying to be made, but...no. I just don't like it. So I am probably going to pleat to the white stripe.
    What I now have is 4 yards of very nice acrylic fabric.
    Once I get this washed up (Wednesday, hopefully) I think I'll get my Matt Newsome on and make me a new box-pleated kilt, unless I decide that repleating violates my kilt buying/making hiatus.
    Updates to come!!
    ~Yeti
    Last edited by Brian F; 28th January 08 at 04:00 PM. Reason: Added photos of pleats and fabric
    26th November 07
    Kentucky
    I don't think it counts as cheating on the hiatus, since you already had this kilt, you're just fixing it.
    1st June 07
    St. Louis, MO
    Quote Originally Posted by string View Post
    I have some kilts which have been remade four times - I lost 12 inches off my waist measurement.
    Although I use natural fibres, mostly, it can't be much different using man made if it is in good condition.
    A light ironing under a dry cloth should flatten it out if you want to reposition the creases. The cloth will prevent polishing of the surface, but it is best to work on the inside, just in case, and then you've got your fabric back to reform as you like.
    I find that with hand stitching it is easier to undo, though I put in machine sewn seams which are most likely to be permanent.
    I suspect that I get more pleasure out of remaking a kilt than finishing off a new one - because I have improved a garment rather than just made from cloth.
    Just a heads up - if you try to do this with a full-yardage trad knife-pleated kilt made by someone who uses traditional kiltmaking methods, it won't work, because all of the pleats are cut out to reduce bulk between the bottom of the fell and the top of the kilt.
    1st June 07
    St. Louis, MO
    Duly noted. Thanks for the info!
    27th September 04
    Amelia County, Virginia, USA
    Try telling that to Microsoft when you are "fixing your computer", but I am looking forward to seeing the results. I have an old Sportkilt in desert camo(given to me) and I'm considering ripping out the elastic and velcro, and then reusing the fabric for an Xkilt.
    Jerry, Kilted Old Fart.
    You CAN make your own box-pleated kilt, you know. Honest, you can. Will it be as nice as one of Matts? No, almost certainly not. But will it be pretty darned nice? Yup.
    We oughtta talk.
    Alaskan Kilted Guy is offline Membership Revoked for repeated rule violations.
    11th July 07
    Fairbanks, Alaska
    Good luck with your project brother. I hope it turns out well for you!
    You're a better man than I am Gunga-Din.
