Results 1 to 10 of 14
    20th August 08
    St. Paul, MN
    Straps 2? 3? & a good source
    I am considering 2 vs. 3 straps. My local saddle shop is making me black 1 1/4" straps with holes 1/2" apart at a VERY reasonable price- bordering on ridiculously low. (St. Paul Saddlery 651-222-5616) They did not have a very good selection of buckles so I will get them elsewhere. I found a nice silver kilt pin on Ebay so I'm, all set in that department. I was going to go the 2 strap route, but what are your thoughts?
    30th March 05
    Kentucky
    3 straps isn't really necessary on the common modern kilt, so 2 should be fine. The last few kilts I've made have had only two straps, and I really haven't noticed a difference in the overall look of the killt at all.
    Two straps is fine, my Isle of Skye, Royal Naval Association and Graham of Mentieth kilts, all from different makers, all have two straps, the third tends to pull on the apron and over time can skew the look of the tartan, so I just stick with two now.
    25th March 07
    Brampton, ON, Canada
    I like the 2 strap myself, the apron seems to fall better.
    14th March 06
    I much prefer wearing only two straps and buckles. The third often pulls the kilt unnecessarily and isn't functional at all, as far as I can tell. It only restricts movement and shows off a paunch, if you have one
    20th August 08
    St. Paul, MN
    OK
    Two straps it is then. Thanks!
    22nd November 07
    US
    Interesting... The top two straps and buckles would normaly be covered by a belt or a waistcoat; unless it was very casual...
    So, if you do away with the third lower buckle, which seems to do more harm than good, then you no longer have to worry about the metal of the buckles or the leather of the straps matching the rest of the leather and metal of the outfit.
    I guess there's no way to put a stabilizer around from the third strap to the buckle, behind the canvas to take up the tension...
    That's why the second strap on the apron side (if a kilt has one) should be buckled loosely. And, as many have said, the second strap doesn't do anything, and the kilt hangs better without it (unless you're a dancer and need the second strap to control the flapping of the apron during dancing).
    22nd November 07
    US
    That makes sense, Barb.
    I'm at a point in altering my SWK where I am considering adding some kind of interfacing to the aprons. I might remove that strap and buckle in the process.
    My only other thought is to set that strap up so that it can be interchangeable (black/brown) and attached with an elastic loop to minimalize any pull on the apron. Maybe even a false strap that is not attached to the apron, but the under apron instead, would work.
    (It's a contemporary kilt after all.) Still thinking about how that might be done, though.
    20th August 08
    St. Paul, MN
    straps
    I'm no too happy wih the saddle shop sraps. He only had chap leather which is suede texture on one side. He also did kind of crappy job of cutting the leather
  1. 2 straps vs 3 straps
    By be da veva in forum Kilt Advice
    Last Post: 11th June 08, 05:40 AM
  2. Source of good cloth
    By Martin S in forum General Kilt Talk
    Last Post: 19th June 07, 10:37 PM
  3. some good sites for you good people
    By Deasan in forum General Kilt Talk
    Last Post: 1st June 07, 04:58 AM
  4. Good sport kilt, good dog
    By Roan Carter in forum General Kilt Talk
    Last Post: 2nd February 07, 09:59 PM
  5. The straps don't lie...
    By Robin in forum General Kilt Talk
    Last Post: 12th September 06, 03:55 PM
