Results 1 to 9 of 9
    Removing kilt basting: the ideal tool!!
    I just stumbled on the ideal tool for removing kilt basting - a knitter's cable stitch needle. It fits comfortably in your fingers and is easy to slip under basting threads to pull them out. The end is pointy enough to work but not pointy enough to snag the kilt. I've seen pics here on the forum of people slipping knife blades under kilt basting to remove it, and I've nearly had a heart attack!
    NOTE! Since the time when I originally made this post, I have discovered that, if you use a plastic cable needle to take the basting out of more than a couple kilts, the thread actually wears deep grooves in the plastic. I now use a METAL cable needle!
    Anyway, here are some pics:
    Fits comfortably in the fingers.
    Just slip under, and pull out.
    22nd November 07
    US
    Neat! I just happen to have something a lot like that.
    19th May 08
    Oceanside CA
    Great repurposing of a tool! Where did you get that pretty yellow one, is it all plastic? I've only found metal ones, but haven't looked that hard (actually planning to use them for knitting, but one tool = two jobs is always better!).
    8th September 08
    Redlands, CA
    I will be sure to forward this to the Mrs. She is just finishing up her class with Elsie at Blandfords in Rancho Cucamonga. Thanks for the great tip!
    Err, well, I found it under some papers on a table in our house when I was cleaning things up (heh heh). It belonged to our daughter, who's an avid knitter. I'll ask her where she got it.
    Excellent idea barb, thanks for sharing on xmarks.
    13th January 08
    Iowa
    great idea
    14th August 07
    Halifax, NS
    I don't usually find anything that useful when cleaning. Maybe Barb should come and clean my house and see what she finds?
    2nd July 08
    Port Washington, NY
    Great tip, thanks!
    "Before two notes of the theme were played, Colin knew it was Patrick Mor MacCrimmon's 'Lament for the Children'...Sad seven times--ah, Patrick MacCrimmon of the seven dead sons....'It's a hard tune, that', said old Angus. Hard on the piper; hard on them all; hard on the world." Butcher's Broom, by Neil Gunn, 1994 Walker & Co, NY, p. 397-8.
  1. describe the general features of your "ideal" kilt
    By Alan H in forum Contemporary Kilt Wear
    Last Post: 16th October 09, 11:52 AM
  2. Removing Kilt Pin Rub Stains
    By Abax in forum DIY Showroom
    Last Post: 2nd July 07, 12:27 PM
  3. removing gold plating from a kilt pin...
    By macwilkin in forum Kilt Advice
    Last Post: 21st December 06, 10:34 PM
  4. How to remove basting stitches on a new kilt
    By Kilted KT in forum Tutorials & How-To's
    Last Post: 31st July 06, 10:57 AM
  5. Tool Time Episode with Tim in Kilt...
    By richardljohnson in forum Kilts in the Media
    Last Post: 27th November 04, 03:51 PM
