Results 1 to 10 of 13
    2nd September 09
    Ohio
    Tartan doublet DIY notes and details.
    Quote Originally Posted by scotchmaster View Post
    Hothir Ethelnor,
    Can you post some more in depth pics of this jacket? and a more complete explanation? It is intruiging... I would like to see and know more.
    Quote Originally Posted by okiwen;
    That coat is cool as hell! I have to have one!!! Is this a pattern you made and tailored yourself?
    To stop from further derailing another member's thread I'll take questions here regarding my tartan doublet.
    Here are some previously posted pics.
    Here is what I have already said about it.
    My coat is based on McCall's pattern M4864
    Changes I made were to totally recut each pattern piece along the bottom adding ten inches to the back and side pieces and making a smooth curve from the edge of the front piece down to the back pieces. I ignored the sleeve caps and the peplum (waistbandish pieces)
    I made cuffs using a different pattern for an Argyle jacket although they are a very simple shape and easy to make. I also pinned the darts together before cutting the jacket out as I didn't want darts interrupting the tartan pattern on the front of the jacket.
    One thing I did was to fuse lightweight interfacing to each piece so that they didn't skew out of shape as woven fabric is stretchy on the bias.
    Scotchmaster would like more pics so I'll take those as I have time and update this thread over the next week.
    17th October 05
    Houston, TX
    Seriously cool there, Gabe! I wonder how bright my MacLeod of Lewis would be in this pattern?
    Oddment in Residence
    25th December 08
    Lotus Land
    Quote Originally Posted by D.A. Guertin View Post
    ouch
    20th April 08
    Boston, MA
    You would be easy to find in a crowd...
    Scotchmaster
    ALBA GU BRATH!
    2nd September 09
    Ohio
    is right. I imagine someone could pull the look off. I would prefer not too try...
    I chose Gordon because it has a simple visible pattern (and I happened to have the cloth left over from another project) I like simple clothing so I was wary of a tartan doublet in the first place because I didn't want to look over the top but it turned out so nice I would like to try it with other tartans as I have the chance.
    (anyone think that a pv doublet in X-marks tartan would be exceptionally pleasing?)
    3rd August 09
    Fayetteville, North Carolina
    Ok...I have questions!!! I'm close to getting started on my doublet project...I'm going to be making something open fronted and collarless like these. My questions are:
    Did you use any shoulder pads in your jacket construction? Sleeve cap?
    What type of interfacing/interlining did you use? Any hair canvas?
    At risk of sidelining this thread, I'd ask anyone else with tailoring knowledge to provide inputs on these questions also...either here...or via PM. Thanks. No issues with your posts on my thread Gabe...we're all friends here...discussion is welcome!
    29th April 07
    Columbia, SC USA
    Quote Originally Posted by longhuntr74 View Post
    I have not done so, but I'd say "yes" to all.
    Here's a very accessible book that describes 3 levels of construction (fusible interfacing, machine sewing, hand sewing). Tailoring: The Classic Guide to Sewing the Perfect Jacket
    2nd September 09
    Ohio
    I did not use shoulder pads. The pattern didn't allow for them and I was unsure if they were historical so I didn't bother.
    I used lightweight fusible interfacing on every pattern piece to keep them from stretching out of shape. I also used heavy kiltmaking hair canvas on the front pieces.
    3rd August 09
    I was thinking the same...
    Good thoughts on fuseable...I'm certain I'll be using a combination for the vest and coat I will be making as well. I know that 18th century jackets did not have shoulder pads...which is why I asked. Curious about modern tux and dinner jackets...I'm thinking that formal jackets may not use them today either. I see them as more of a sportcoat/suitcoat type of thing...perhaps some very thin ones of felt might be appropriate. I'm pretty broad shouldered as it is...so anything I put in the shoulder will simply be for smooth lines and to fill the clavicle area vs. trying to create a broad shouldered look. Does anybody have any thoughts or knowledge of tailoring that could confirm or deny shoulder construction in most modern doublets?
    On a separate note, I made a pressing ham last night...turned out great, cost me nothing, let me get rid of a bunch of wool and cotton scraps I had been saving for no reason, and only took about 45 mins or so to make. I love fast simple projects!
    24th November 08
    Caldwell Idaho USA
    making a doublet, or any other jacket
    Always make sure to pre-shrink interfacings, lining fabric and outer fabric.
    I've learned the hard way. If fabrics aren't pre-shrunk, they can pucker and pull when interfacing is ironed on.
    I've taken lately to not using fusible interfacing.
    Rather, I will use hair canvas and fusible web. Which is a very light weight, heat-set film.
    I find that I get a better bond with using the fusible web than fusible interfacing. Fabric stores will be able to point you to the right product.
    It means more work, in that you have to cut out a piece of the stuff for each garment part that is to be interfaced, but all told, it's a helluva lot faster than tailor basting all interfacings in place.
    Same procedure for fusible interfacing, in that it is heat set, with the fusible web sandwiched in between the hair canvas and the wrong side of the garment piece.
    It everything has been pre-shrunk, and ironed flat, there should be no problems.
    Regards aye,
    T.
  1. Highland Evening Doublet made of Strome Tartan
    By creagdhubh in forum Traditional Kilt Wear
    Last Post: 19th August 10, 11:08 AM
  2. Final notes (and some pics) from MSOPD
    By Phogfan86 in forum Celtic Musicians
    Last Post: 14th June 09, 08:35 PM
  3. A few notes from the MSOPD
    Last Post: 10th June 09, 09:51 PM
  4. Braemar Cuff Details, and Argyle pocket details?
    By Bugbear in forum How to Accessorize your Kilt
    Last Post: 8th May 09, 05:18 PM
  5. Corduroy Jacket Conversion Notes and Links
    By Bugbear in forum DIY Showroom
    Last Post: 10th November 08, 07:52 PM
