22nd June 11, 12:32 PM
Third Buckle/Strap
Is it me, or is the third buckle and strap on a kilt useless/a nuisance? I'm thinking of getting a new kilt (number 4 in my inventory, but one of over a dozen I've owned), and I'd like to ask that kiltmaker to leave it off. Will this affect how the kilt is made? What purpose does that extra buckle serve?
Thanks!
Jared the Brus
22nd June 11, 09:01 PM
Check out this recent thread on the same question.
22nd June 11, 09:27 PM
 Originally Posted by Mael Coluim
Right. Generally unnecessary, if not an actual pain i' the ****.
I have kilts which have been done both ways. . .Well, that sounds awkward, what I mean is I have kilts with three straps and kilts with only two. . .and while the presence of the 3rd strap doesn't bother me, I'd as soon do without it.
23rd June 11, 07:31 AM
I like the two-strap style better than the three-strappers, too, and I also like the way Matt Newsome makes his kilts. The left strap fastens to a buckle inside the kilt, so there is no "buttonhole" for the strap to pass through. You might want to investigate that option with your kiltmaker.
--dbh
23rd June 11, 07:38 AM
Sorry to rehash. I couldn't find the original thread. One last question: if the left strap/buckle are on the inside, isn't that uncomfortable? Does anyone have a picture of this?
23rd June 11, 08:09 AM
 Originally Posted by piperdbh
. . .and I also like the way Matt Newsome makes his kilts. The left strap fastens to a buckle inside the kilt, so there is no "buttonhole" for the strap to pass through.
I have two kilts from Matt (and two more in the queue to be made eventually), and this construction style is my absolute favorite. It seems odd, but in all my considerable wearing of them to date no one so far seems to have noticed that there is only one visible strap & buckle.
23rd June 11, 10:26 AM
My latest acquisition (a SHO 4-yard box pleat) has that same style internal buckle on the left hip. I don't care for it, and would rather have it on the outside.
For starters, it seems more difficult to put on. With the external buckle, and the strap passing through a "button-hole", I can let the apron hang there on the strap while I fish the end of the strap into the buckle and get it adjusted. With the internal style, though, there's nothing to support the outer apron while I'm putting it on. It hangs from way around on my left side, at the point where the strap is stitched to the fabric. I need three hands: two for buckling the strap, and one for holding the apron. It's just awkward.
But also, if for some reason I want to adjust the left hip strap a notch tighter or looser at some point, I have to undo everything to get to it. An external strap is much easier to get to for adjustment.
And lastly, by moving it inside, there's less fabric between your hip and the buckle itself, which means less padding. I'm not going to say it's uncomfortable with it inside (I haven't noticed any discomfort), but I could see potential for it being less comfortable having the buckle inside rather than outside.
I just don't understand the purpose of putting it inside. If it's a matter of not wanting it to show, well, OK. Most people wear belts or otherwise have that area of the kilt covered by a waistcoat/jacket/whatever. So I really don't see why it's worth the additional hassle to have it inside unless one doesn't wear anything over that part of the kilt and is overly sensitive to having a visible buckle.
Can someone explain to me the reason they are being made this way? Surely there's an advantage that I'm not seeing.
As for the "third" buckle on the right hip, I apparently am in the minority. I like it. Rather than the entire kilt just hanging from the top, the third buckle helps it be more of a form-fit to the shape of my hips. And yes, if you tighten it too much, it will pull things out of whack. But just a slight bit of snugness on that lower buckle, in my opinion, makes my kilt fit better to me. It also reduced outer apron flopping (which isn't that big of an issue with a 16-oz wool kilt, but definitely was on my old PV kilt that didn't have a third buckle).
Plus, I just like the looks of the third buckle. The top two are normally hidden by a belt, and I like to see the lower hip buckle exposed. It just makes the kilt look like more of a man's garment, having a leather strap and metal buckle showing, as opposed to just fabric.
23rd June 11, 12:03 PM
Tobus...I absolutely can explain why!!
Firstly, I don't see where it's any harder to put on...I guess I really don't understand why you need to hold the apron while you're buckling the strap? That being said...I can appreciate your preference for one style over the other and your point about being able to tighten/loosen your kilt is very valid.
Now to answer your question:
That style of system was implemented due to an alignment problem that occurs when making a box pleated or casual kilt with wide pleats. In a traditional tank, you leave a slot in your second pleat to pass the strap through. The location of this slot is ideal and allows you to buckle evenly on both sides.
When the pleats become 2" wide, if you wanted to use that same technique, the slot would either be halfway around your back or you'd have to cut a hole through the middle of your pleat and then sew in some sort of bound buttonhole type of arrangement. Therefore, instead of cutting through the kilt, an alternate method was developed (not sure if this was something that Matt Newsome invented or if it draws from old examples?). As I've implied, even if you're making a box pleat, you certainly could cut that hole and make the slot...it just requires extra work in the stabilizer/canvas/lining stages to finish it and such.
When I make my next kilt (a 6 yarder), I'll have to decide whether I can use the second pleat gap technique or whether I need to "create" a slot. This will be based on pleat width. Regardless, I think I will be going with your preferred arrangement of the traditional outer buckle. I have nothing against the other arrangement, but prefer the symmetry of the traditional method.
23rd June 11, 02:44 PM
Extremely valid point(s) Tobus. I am at a bit of dilemma, indecisive I guess. I am not sure if I want to remove the third strap and buckle from my kilts, partly because I am terribly afraid of harming my kilts, and partly simply because I kind of like the look as well, or am I just accustomed to it? I never really gave it much thought in the past. All of my kilts were made by Kinloch-Anderson and came standard with the third strap and buckle, and I never requested only two, as I was a wee bit ignorant of that aspect of kilt tailoring. Should I remove the third buckle on one of my 8 yard, 16 ounce tanks and see how I like it, then go from there? Can someone say, indecisive? Perhaps I should send a kilt to Matthew Newsome and have him remove the third strap and buckle for a reasonable fee, so I don't mess my kilt up?! Not trying to make a huge deal about the issue, but what am I to do?!
Many thanks,
23rd June 11, 03:21 PM
I'm not doubting your experience, but please allow me to share my own. Kilts with an external left buckle are certainly the norm, but having owned and worn both styles for years, I can honestly say I do not find either one more difficult to put on than the other, and I can feel absolutely zero difference between the two when I am wearing the kilts.
So why do it?
I first started doing it as a "neat feature" of my kilts. The idea was taught to me by Bob Martin, and he himself saw it used on a kilt from the 79th New York Cameron Highlanders he examined in the Gettysburg Museum. Remember, these kilts were made by New York City dress makers, who had no training as "Scottish kilt makers." The straps they used were actually made from the same tartan cloth as the kilts. And they used an interior fastening structure for the inner apron.
So Bob started to mimic this system with the leather straps of today. And he showed it to me. It just seemed interesting for my "nineteenth century" style box pleated kilts to have a unique strap and buckle arrangement that dated to the nineteenth century, as well.
However, since using that system almost universally for some 500 kilts now, I do have to say I see some advantages to it. And the primary advantage comes when making future alterations to the kilt.
Let's say you need your kilt taken in by 2". No problem. I remove the inside strap, and the outside buckle, and sew them each back on exactly 2" from their original position. Easy-peasy.
It's not quite that clean-cut with the more usual exterior arrangement which requires a button-hole. That button-hole is a stationary feature of the kilt. You can't move the hole (not without some major retailoring of the kilt). So any alterations must work around it. What that would mean, in my above example, is that the leather strap on the inside apron would be resewn in 2" farther from the edge of the apron, which would either mean some significant overhang on the apron edge, or you'd have to rehem the apron itself.
To me, it just makes alterations easier with my method. But to each his own!
Last Post: 12th August 09, 02:56 AM
By ninjaschopheads in forum General Kilt Talk
Last Post: 6th March 09, 07:43 PM
Last Post: 26th April 06, 09:51 AM
By KiltedCodeWarrior in forum How to Accessorize your Kilt
Last Post: 8th November 05, 10:20 PM
