Results 1 to 10 of 16
    25th January 11
    Winfield, MO (originally from NE Scotland)
    doublet from cutter and tailor pattern book
    These have probably been posted here before, but on my search for info to do a doublet conversion i stumbled across them... Might be useful to someone
    19th May 11
    Olive Branch, MS
    Very interesting to see this as a patterned diagram. I always expected something like this to be much more complex than the diagram would indicate. This of course does not include any details on padding the shoulders or quilting the chest but the body portion of the doublet is very similar to the Civil War era Union "mounted services jacket" patterns readily available from a number of sutlers. Another option might be basing one on the Confederate Richmond or Peter Tait import jackets that are also commonly available. With a few alterations to the cut of the body and a little creative work to draft the cuffs and skirt pannels the jacket pattern would be a great place to start for someone without formal tailoring training but skilled enough with a needle to handle a pre-sized pattern.
    Something to table for the future should I find myself in desparate need of an excuse to sew yard after yard of trim onto a jacket...
    Note the various ways the flaps/skirts/tashes are shaped there.
    The Army adopted doublets in 1855.
    Initially the tashes were shaped like this. Their origin and function as pockets is obvious. Here are the original 1855 pattern doublets:
    In 1856 the Army changed the doublets from doublebreasted to singlebreasted and the tashes changed too. Here's the 1856 pattern, being worn in 1865. The ORs' tashe shape would evolve from this to the classic shape seen up until Full Dress was abolished in 1914. The Drum Major here shows a tashe shape often seen on Officers' doublets.
    Here are photos showing the classic ORs' tashe shape seen in the last quarter of the 19th century up to 1914:
    This doublet is the perfect example of the extremely elegant tashe shape common on 1881-1914 ORs' doublets:
    Officers' doublets usually had their tashes shaped a bit differently. This shape is common, not elegantly flaring like the ORs', but straight and a bit narrower. The buttons are often pushed closer to the edges on Officers' tashes.
    This Officer's doublet has tashes shaped more like ORs'.
    The lower patterns in the OP above show very squared-off tashes; these do appear occasionally in old photos of Army officers.
    25th March 08
    Louisville, Kentucky
    You might find these pages of more interest for civilian wear:
    What years are these patterns from? Thanks!
    1st June 08
    San Angelo Texas
    Could anyone tell me if the facings were different on the 1855 uniform from the Napoleonic uniform. In particular I am wondering if they changed from each regiment having there own facings, to a standard facing for all regiments?
    25th January 11
    No date on the original book, but it's in the 1893 - 1898 category...
    http://www.costumes.org/history/100p...ttersguide.htm
    Lots of nice information on there if you poke around...
    25th January 11
    Quote Originally Posted by JSFMACLJR View Post
    It's interesting to note that the flaps on the mariner cuffs of the coatee used to go to the bottom of the sleeve, but fashion etc has ended up with them floating higher up the sleeve with no real reason nowadays...
    25th January 11
    I'm no expert, but i suspect small changes like the flaps may have changed based on the regiment... Kind of like the buff facings on the black watch mess dress, and the buttons going to the top of the collar.
    I do seem to recall an episode of Sharpe where they suggested that the rifles were going to be put in scarlet uniforms like the rest of the regiments (met with derision by the rifles) and the thought was that the rifles had the right to wear green for some reason (a vicotory somewhere?)... Only fiction i know....
    10th June 10
    Western Washington State or s/v Lady Washington
    [QUOTE=JSFMACLJR;995493]You might find these pages of more interest for civilian wear:
    Wow, Thank you incredibly much. Several years ago I made a frock coat from period lofting instructions such as these. I had been planning to cut down the pattern for a kilt jacket but now this is much better. I have some black Pendleton wool left over which should do nicely. Again thank you.
    Elf
    -atr: New Zealand proverb
  1. "Cookie Cutter" Pipe Band Dress
    By OC Richard in forum Traditional Kilt Wear
    Last Post: 30th October 10, 06:05 PM
  2. formal jackets and the cookie cutter aversion
    By MacLowlife in forum Traditional Kilt Wear
    Last Post: 28th October 09, 02:29 AM
  3. Tradition of Non-Cookie-Cutter Kilt Jackets?
    By Bugbear in forum Traditional Kilt Wear
    Last Post: 24th April 09, 04:25 PM
  4. Doublet Pattern
    By Mark Keeney in forum How to Accessorize your Kilt
    Last Post: 28th September 06, 06:30 PM
  5. Pattern for montrose doublet?
    By Nick in forum How to Accessorize your Kilt
    Last Post: 7th March 06, 11:51 AM
