Results 1 to 10 of 13
    9th September 11
    Penacook, NH
    A new sgian dubh
    Well, a while back I made a sgian dubh. The carving on the butt of the handle I liked. The blade was off a boot knife, and the hilt had to accommodate the existing sheath.
    It works out fine enough in biker boots, but it's a bit bulky for kilt hose. It was time for a new one. But this time, I started from a rougher point. Specifically I started with an old file that I had kicking around. I'm not sure how old it is, but from the quality I'm betting at least 30 years old.
    Now, I don't have access to a proper forge. I do have an oxyacetylene torch, a large ball pien hammer and a good sized chunk of I-beam to hammer on.
    So, heat the file...
    Get it nice and glowing hot, just before it starts sparking. Lay on I-beam and hammer away.
    If you angle your strikes you can stretch the steel and thin it out.
    Here it had a standard point, but I didn't like it so I hammered it more to a drop point.
    It has a crude surface and little flaws. There are places it almost has a fish scale pattern from the original teeth of the file. All these things endear it to me and make it more mine.
    9th September 11
    Penacook, NH
    Then it was time to make a hilt. This time I took a billet of brass and put it on a mill.
    I measured out the width of the blade and got a tool of the correct diameter. From there it was just slow passed, back and forth. Each pass cutting a little deeper.
    Then flip the billet over and repeat, only this time cutting the width of the tang.
    Heat it up, try to fit it.
    I wasn't overly thrilled with the final fit.
    So I made a second one, but refined my measurements. It came out much better.
    Now to select my handle material...
    7th February 11
    London, Canada
    Dying to see the next steps!
    15th April 07
    State College, PA
    Nice work!
    Wallace Catanach, Kiltmaker
    9th September 11
    Penacook, NH
    So, did a bit of work on my sgian dubh. First off, I selected a piece of antler shed by a white-tailed deer (for the animal lovers this was a spring shed, no harm came to the buck by my hands).
    Now, tonight's first stop was the belt sander to get the end straight and flush.
    Next was to center the antler on the brass hilt and trace its outline. Then came some rough cutting and grinding.
    Roughed in
    Then, I wrapped the blade in vinyl tape, and clamped it in a vice with the brass hilt in place. I boiled the antler for about an hour to soften the inner spongy material. Then line it up and push it on.... HARD. A few taps with a hammer and here we are.
    Next will come fine grinding to blend in the shape of the brass to match the antler, and give it a finished shape near the blade.
    3rd January 08
    Illinois, USA
    4 Post(s)
    Great looking project. Can't wait to see the fully completed sgain!
    Member Order of the Dandelion
