6th March 14, 10:08 AM
Salmon fly kilt pin SBS
I had seen somewhere a salmon fly kilt pin and thought about doing a trout fly kilt pin. I like my trout fishing and tie my own "Clyde Style" flees; small lightly dressed patterns. A Clyde style with three turns of hackle is a heavily dressed fly. Having given it some thought I decided against this as I thought that scaling up to kilt pin size would ruin the overall effect of the fly/pin, so I reverted to the salmon fly which to me are just "lures" . i mean, who ever saw a hatch of Ally Shrimps or Dunkelds??
I decided on a nice bright hair wing pattern, they are easy to tie. Its a sort of yellow/garry dog pattern. I was fortunate in that the kilt pin fitted the jaws of my fly tying vice. If you have never tied a fly before and want to give it a go, a pair of vice grips would suffice. I'm sure its not beyond the capabilities of the average X Marker to cobble something together to do this sort of thing. so here is my SBS on how to do it:
Kit
A vice of some sort
A kilt pin
Some varnish - quick drying
Sharp fine pointed scissors
Materials
Substitute your own versions if your not a fly tyer
Black floss
Yellow floss
Silver wire/tinsel
Yellow deer hair
Orange deer hair
Blue deer hair
Method
Wind the black floss down the hook, sorry pin, to near the bend and tie in lengths of yellow floss
Wind the black floss back to the front of the pin to the point where you want the tag to be
Wind the yellow floss over the first layer of black floss up to where you stopped winding the black floss
Use a couple of turns of black to tie in the yellow, trim the yellow and tie in the silver tinsel
Should have taken more pictures. In this picture you can see the yellow tag and just see the tinsel ready to be used to form the rib once i have wound the black floss all the way back to the start
[IMG] [/IMG]
Continue the black floss back up to the "head" of the fly. Make a rib of silver up to the head and tie in with a couple of turns of the black floss and trim the tinsel.
[IMG] [/IMG]
The thing you can see hanging from the black floss is a bobbin holder. A peg would do the keep the tension on the floss.
Now get your hair wing material and size a pinch of it for the under hackle. Tie it in with a couple of really tight turns of floss using the "pinch and loop" method. If you are not a fly tyer, Google it, its easier to watch than explain. Trim the excess material sticking over the front of the pin
[IMG] [/IMG]
Repeat the last step for the wing using one or more colours of material, blend them if it takes your fancy.
[IMG] [/IMG]
Once you have the "wing" tied on, lift up the "wing" and take a turn or two of the floss behind it to make the wing stand up a bit. Then back to the front with another turn or two of the floss. I then soaked the wing material and floss that would be contained in the finished head in varnish to secure the lot. When it was nice and tacky I trimmed the excess wing material and formed a bigish head to fill the gap on the pin shank. I'm not too good at this size of fly head as I'm used to small delicate trout flies.
[IMG] [/IMG]
The finished article
[IMG] [/IMG]
The Following 7 Users say 'Aye' to David For This Useful Post:
