Results 1 to 10 of 11
    18th August 16
    Vermont
    Question on Belted Plaid
    I am working on a Jacobite (45) impression and i had a question on wearing a belted plaid...
    Would the dirk / sporran be suspended from the same belt that secures the plaid? Or would a second belt be worn?
    Many thanks for any help / input!
    James
    5th August 14
    Oxford, Mississippi
    I will post this link to another thread (as I did for new member Keagan from Germany). Look to the first posting for photos of outfits of the periods. Later reading will cover the dirk and other items carried by the Highlanders.
    http://www.xmarksthescot.com/forum/f...te-garb-51320/
    Asking and answering is what we do here. Discussions clarify the details and share opinions of the Rabble.
    18th August 16
    Vermont
    Thank you
    Thank you Tarheel... A 44 page thread may take a bit of wading but if you think the belt question is answered there that's where I'll start!
    James
    26th September 05
    Indiana
    One or two belts could be a class distinction, or just a fashionable one.
    If your sporran has a single hanger loop, then it can be worn on the same belt as what holds up the great kilt. If it has a pair of hanger loops, then its designed to be worn on a separate belt. There are very few all leather non cantled sporrans that survive, so its hard to make a hard and fast rule one way or the other.
    Here are some photos of origional sporrans that I have gathered from across the internet. All I can say is that they are from the greater 18th Century, as I dont have the collection history and particulars saved.
    All Leather sporran:
    Sporran Cantle designed to be worn on a thinner second belt:
    Cantled Sporran with one single loop that could be worn on the same belt as what holds up the plaid:
    One thing I will caution you on, stay away from the round blacksmith made old tyme buckles, they are modern creations.
    here is a a belt and buckle recovered from a bog body, its a typical European buckle of the period. You can find this buckle from many of the reenactment supply houses, its often called a "French Marine" buckle
    2nd January 10
    Lethendy, Perthshire
    17 Post(s)
    I recognise that second sporran .
    26th September 05
    Indiana
    Please let me know the particulars! They have been snagged off the net over the last 20 years with no info retained on them
    5th August 14
    Oxford, Mississippi
    Sorry about the length of the thread James. Some of the earliest (XMarks youthful days) posts were fresh and unexplored as topics in a public forum, thus the thoroughness.
    I have found that a subject will follow a train of thought by one member (unless high jacked off topic) that may lead to many aspects of the concept issue. In this case, Jacobite garb includes belts, dirks, shoes, hats, material weaves and patterns, etc. I hope you find a lead and will pass that single tidbit on to the rest of us with your particular views and experiences attached.
    Kilt on with confidence.
    Thanks for that link, Tarheel!
    So interesting. I only got partway through, I'll need to finish it later.
    I've always been fascinated by the dress of that period, though I've never worn it.
    I did have a costume that I used to wear to RenFaire back around 1980 which was, more or less, the middle ground/missing link between the traditional Irish brat-and-leine costume and Highland Dress: a large wool rectangle with fur trim all around which could be worn either as belted plaid or brat according to whim, with leine and crios. I found a great bit of wool for it with a pattern halfway between tweed and tartan.
