11th February 26, 02:57 AM
Royal Regiment of Scotland - Kilt Sizes (Current)
In the past 4 month I spent hours and days trying to find my way through the kilt jungle. First I aquired a kilt made by the "Scottish Higland Kilt" company for around 90 bucks. The full length was 24" and it does fit a waist from 34" (printed) to max 36". The fabric wasn't wool after all and knowing that the events attending will be around -5 degrees celsius and i will be outside for about 6-8hrs, i came to the conclusion that the fabric is not warm enough. I gave it at try with wind chill -8 for 30min and i was freezing.
As a solution I found the idea about a scottish regiment kilt. I already have regiment trews and logically the kilt must be the same good fabric.
I bought a new RRS Kilt off ebay for 160 bucks in sizes 176/88/104. A good match for my belly I was thinking. When it arrived, surprise surprise. The sizes wasn't really matching. the 88cm was probably rather an 86cm at its widest button hole and soon i noticed that the length was around 25" to 26". Thats when the research began.
Meanwhile I understand that the overall length of the regiment kilt is longer than the civilian regular kilt and that it is worn higher than the regular kilt. Obvious think case my RRS No1 Piper jacket was always giving a glimps on my t-shirt underneath when wearing the civilian "Scottish Highland kilt". Jacket hem and top of the kilt are just right at the belly button, but not overlaping.
I found a lot of valuable information here in this forum. Most of it kind of old, back from 2015. I thought to myself I wanna give some reference information for future buyers. All the information is applicable only for the current RRS Kilts. The older ones were sized differently.
It has to be noted that the indicated sizes of the waist is measured at the largest possible position at the outer belt hole. So it has to be understood that you can go down from 88cm to 85cm but never to 90cm. This as an example. The older regiment kilts you can find on ebay, "genuine" not pakstani repro. Are measured at the middle button. This gives you one inch more and one inch less. Another word of caution. Regiment kilts, if issued, not like mine, might have been trimmed for the person that is going to wear it. I strongly recommend to check the real measurements before buying it. For me retruns on ebay cost a fortune here in Switzerland. I learned my lesson.
Find the table attached below with the available sizes.
1st number: refers to the persons height in cm
2nd number: refers to the persons waist in cm
3rd number refers to the persons breech in cm
The lenght is the full length and fits above the belly button in order to overlap with the regiment piper jacket no1.
The Following 2 Users say 'Aye' to MartinMU For This Useful Post:
11th February 26, 07:08 AM
The Following 4 Users say 'Aye' to OC Richard For This Useful Post:
14th February 26, 03:37 PM
Thank you kindly for sharing.
Also, I must remember not to take a photo together with OC Richard, or I'll end up being used as an example of how not to wear a kilt :-)
The Following User Says 'Aye' to User For This Useful Post:
15th February 26, 09:57 AM
The diaspora; obviously an up-scale gathering
 Originally Posted by OC Richard
Thanks for that! It should be a sticky, due to how often members here window-shop military kilts, and sometimes purchase them.
A dispensation must be given to the gent at far left, he must have been 6 foot 8 or thereabouts.
My GOODNESS, that single picture tells so MANY stories. MY attention was drawn first to the giant on the left, but NOT because of the too-small/too short PC/waistcoat, but its LAPELS, even a bit worse than my own, with BOTH of them probably having been sourced from a vendor of ex-hire clothing at a local Highlands Games gathering.
Then there are the hose. YOURS are glorious.
And the shoes. Enough laces embracing the ankles to make Jock RUN in the other direction.
But, your sporran? I imagine you have a collection in your closet that requires a separate CLOSET, but I HAVE to know a bit more about that example.
(ducking; all in good fun).
The Following User Says 'Aye' to jsrnephdoc For This Useful Post:
16th February 26, 03:36 AM
Worry not my dear chap, running is not something that I can do these days. Besides, I have seen enough laces embracing ankles---including some rather pretty ones on ballerinas------not to loose much sleep over them!
17th February 26, 04:32 AM
And me too! I never wear Ghillies with Evening Dress, always buckled brogues. BUT as I was getting dressed that day I pulled out my old Patent Leather buckled brogues only to find that the "leather" had disintegrated. My only choice was the dreaded Ghillies.
It's one of my retirement-project sporrans. In another fashion problem that day, I pulled out my traditional goathair Evening sporran only to find that I had forgot to attach the cantle, which fell off.
So a not-quite-proper sporran was pressed into service.
Here's my Margaret Morrison "hunting" sporran on the left, it's basically a reproduction of a 1920s/1930s style.
The other three are my projects.
The Following 2 Users say 'Aye' to OC Richard For This Useful Post:
